2010-05-19, 22:48
Trying to apply all this to my Hama 00052451, at the moment the remote does not do anything when pressing most of the keys
Before I will try with another remote, could someone please put all the info here together for a linux newbie?
I am getting the same error message.
How did you know that your Lircmap.xml was corrupted?
I used nano to edit the file (in /home/xbmc/.xbmc/userdata), here is hwo it looks like:
I am pretty sure I missed something, maybe someone could give me a hint...
jbernardo Wrote:For me it still doesn't work. If I change line 83 and 84 in /etc/lircd, commenting them both, then the lirc instance for the "transmitter" won't start:
Code:$ sudo /etc/init.d/lirc restart
* Stopping remote control daemon(s): LIRC [ OK ]
* Loading LIRC modules [ OK ]
* Starting remote control daemon(s) : LIRC [ OK ]
lircd: there seems to already be a lircd process with pid 11060
lircd: otherwise delete stale lockfile /var/run/lirc/lircd.pid
jbernardo Wrote:Also, the remote gets ignored by XBMC, seems like it doesn't see the Lircmap.xml in .xbmc/userdata.
EDIT: My Lircmap was corrupted. Now all I need to do is fix the detection of mouse and power button
<lircmap>
<remote device="linux-input-layer">
<power>SLEEP</power>
<start>HOMEPAGE</start>
<myTV>T</myTV>
<mymusic>M</mymusic>
<mypictures>I</mypictures>
<myvideo>E</myvideo>
<pause>PLAYPAUSE</pause>
<stop>STOPCD</stop>
<reverse>B</reverse>
<forward>F</forward>
<skipplus>NEXTSONG</skipplus>
<skipminus>PREVIOUSSONG</skipminus>
<record>R</record>
<back>BACKSPACE</back>
<info>BTN_RIGHT</info>
<left>LEFT</left>
<right>RIGHT</right>
<up>UP</up>
<down>DOWN</down>
<select>ENTER</select>
<title>BTN_MOUSE</title>
<volumeplus>VOLUMEUP</volumeplus>
<volumeminus>VOLUMEDOWN</volumeminus>
<mute>MUTE</mute>
<pageplus>PAGEUP</pageplus>
<pageminus>PAGEDOWN</pageminus>
<one>KP1</one>
<two>KP2</two>
<three>KP3</three>
<four>KP4</four>
<five>KP5</five>
<six>KP6</six>
<seven>KP7</seven>
<eight>KP8</eight>
<nine>KP9</nine>
<zero>KP0</zero>
<display>KPASTERISK</display>
<clear>ESC</clear>
</remote>
</lircmap>
