Is there such an option in Confluence?
I have many files from a HD camcorder, and even TV Shows I would like to play the first one and have the rest automatically play one after the other.
Possible to add a whole folder to a playlist?
yes just "add to queue" on the folder not the files
Jezz_X Wrote:yes just "add to queue" on the folder not the files
That didn't really do anything for me.
However, in file mode, all you need to do is press "C" (on the folder) to bring up the options and the click "Play", and then the files play one after the other.
MdMa Wrote:That didn't really do anything for me.
that works in library mode as well. right click (or context menu - "C") over a season/show and select play, xbmc will then play all the files in order.
note though that if you have Hide Watched selected, it will still play the files you have watched even though they arent visible on your screen. i tried that with a half watched season hoping it would only play the episodes that were unwatched, but it started with episode one. makes sense as the playlist it is generating is separate from the gui.
