2009-12-09, 21:34
EDIT2: SOLVED!
In /etc/fstab this is what i had to add:
Hey o/ been a long time lurker, but finally made my purchase of a ASRock ION 330, and therefor i am in need of assistance since my linux knowledge is in the hidden paths of my brain-tissue.
So that everyone can understand what I'm trying to achieve i might as well post all steps i have done so far:
1. Installed XBMC Live (Camelot Beta1) on internal drive
2. Setup stuff with usr/pw xbmc/xbmc
3. SSH and login with xbmc/xbmc, made some stuffs based on googling around:
changed in sabnzbdplus:
started SAB
Browsed to http://192.168.1.4:8080/sabnzbd
and everything works fine so far.
However now I'm trying to add it in sab config so that i can save stuff to my NAS (currently a Popcorn Hour a-110 with a few usb disks and internal serves me as it)
Mounted one of the USB's connected to the PCH:
It shows up nice in the right path, however i do not have WRITE permissions from within SAB nor Prompt.
Tried a few other mount methods found when googling, but most of them didn't work, and those who did, was sure as hell not gonna give me write permissions.
Thanks, really! /calmdown.
EDIT: If it helps i can Telnet to the Popcorn Hour and change stuffs, however somewhere there my experience ends, since i have no clue at all on what to edit.
//192.168.1.2/Usb_drive_a-1 /mnt/nmt-usb1 cifs user=nmt,password=1234,uid=1000,gid=100 0 0
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get sabnzbdplus install
$ sudo nano /etc/default/sabnzbdplus
User=
to
User=xbmc
HOST=
to
HOST=192.168.1.4
PORT=
to
PORT=8080
started SAB
$ sudo /etc/init.d/sabnzbdplus start
$ sudo mount //192.168.1.2/Usb_drive_a-1 /mnt/nmt-usb1 -o username=nmt,password=1234
