2009-12-10, 00:40
Hi everybody,
as you can see, this is my first post.
I did search for my problem here , but unfortunately I could find, or understand, a solution.
Hopefully I don't make myself lots of enemies with this post
I'm running XBMC, latest build, on Ubuntu 9.10 with NVidia 190.42 driver.
Videocard - NVidia GForce 8400GS
My Prob is, that, allthough the resolution of my TV (1360x768) and the refresh-rate (60 Hz) matches exactly between card and TV, I still get a small line in the upper 3rd of the screen when playing videos.
Videos have a framerate of either 24 or 25 fps.
[Update: Also videos with a framerate of 30 fps have this little lien, which I find a bit weired, because this is just half of 60Hz. I thought this wouldn't cause any probs.... ]
The xorg.conf has already been modified with Option "DynamicTwinView" "False", that way I got the 1360x768 in 60 Hz. Before that I only could set it to 50, 51 or 52 Hz.
I think that is the point to start, but I simply don't now what to do...
I always thought this would be managed by the player.
Can anyone tell me at least where to look or what to read?
Thanks a lot.
Erik
Thanks a lot.
Erik
