Full Version: Fonts missing!
I recently updated my XBMC and when I got the new one to work as dashboard it seems like the xbox don't find any font files or something. it's all blank so I have to guess my way through everything. kind of like making a midnight snack in the dark...
please help and in the meantime I'm gonna try to see if I can find the problem my self.
I have now noticed that it's only when I'm using the Project Mayhem skin it gets like that. The other skins works just fine
The only reason font should be missing from PM3 is you over wrote a really really old version of the skin with the latest one instead of starting from scratch with it
yeah that sounds about right. It was a really really old one I overwrote. But I did a backup of the old one just in case. Is that something I could use to restore the skin or do you have another way to fix PM3?
to fix pm3 just delete the old one and copy over the new one (providing you have new xbmc)
I'll be damned =) that was an easy fix. Thanks alot my good man!
