Sharpe Wrote:... Most I could do is make it optional.
Sharpe,
that would be great!
Hi everyone - here's a list of the latest additions to the skin since my last update listing.
Version 3.0.4
- Changed Movie wallpaper
- Changed radio button, MPAA classification and movie star rating images
Version 3.0.3
- Added number of items and page labels to alpha scroll info
- Updated Italian language skins - thanks Uli666
- Added French language strings - thanks ppic
- Added German language strings - thanks ubuntuf4n
- Added Smaller Wall view to video files mode
- Cleaned up Home controls xml
Version 3.0.2
- Added Wall View to video files mode
- Provided greater customisation for recent & random items
I'll be asking for these changes along with the previous ones to go onto the official repo in the next couple of days. If anyone spots any problems or glitches please shout out.
Cheers
sharpe,
nice list.
Will check those changes.
Edit: sharpe is there still a plan for adding a toggle
for enabling/disabling the new page alpha scroll-info ?
I am still on Build 3035 and checked your changelog recently.
Cheers.
ubuntuf4n Wrote:sharpe is there still a plan for adding a toggle
Cheers.
Yes that's just been added for the number of items/page number labels but I've left the actual alpha scroll label in place.
THX sharpe,
nice work as always :-)
No worries
Ok I've done some more updates here's the summary:
Version 3.0.7
- Slightly lowered position of simple home controls
- Changed some of the default home screen wallpapers
Version 3.0.6
- Overhaul of all the view scrollbars for a more consistent look
- Removed unused scripts control from homescreen
Version 3.0.5
- Overhualed remaining views into thier own xml
- Overhauled music file views into their own xml
- Made number of items label optional
- Fixed a bug in video OSD settings
- Fixed some DivX flagging issues
Version 3.0.4
- Overhauled music library views to fix remembering list position bug
More updates:
Version 3.0.8
- Changed Home Screen font for one that works better with symbols
- Added Spanish translation - many thanks PatOso!
- Improved Home Screen Film Strip icon
- Continued overhaul of all the view scrollbars for more consistency
Yeah sorry we we're messing with the download links - it's the next post down from that.
I've updated my signature link.
Latest updates:
Version 3.0.9
- Added movie info to Panel Wrap view
- Updated Chinese (simple) language strings - thanks taxigps
- Added support for new Cinema Experience add-on
Details on the Cinema Experience add-on can be found
here. (It's pretty awesome). Once it's set up - you can activate it from the movie info screen by clicking the cinema experience button.
New movie panel wrap view addition screenies:
Incompatible skin, We require version 2.10 or higher.
Getting this error when trying to use the Dharma Version skin on an Xbox hooked up to an older 4:3 TV @ 420p with old school RCA cables.
Pre Dharma version works.
Any ideas?
superrrguy Wrote:Incompatible skin, We require version 2.10 or higher.
Any ideas?
Yeah sorry the Dharma version of the skin isn't designed to work on the Xbox.
Sharpe Wrote:Yeah sorry the Dharma version of the skin isn't designed to work on the Xbox.
If I get rid of the XBox, what do you suggest I get?
Well, this isn't the proper place to ask a non-skin related question (proper forum thread's discussing that already), BUT, i would say any small PC box, an ION based box seem's to be getting a lot of attention lately since it's got H/W accel of HD video's, and plays great out of the box. Just looking at the % thread of user's using what platform, seem's Windows is #1 currently, having most people voting they are using windows (but you can use what's comfortable to you.), and using a computer of your choice, or building a small box to use for XBMC.
This site is a good place to start
