Full Version: [WINDOWS] Audio output device choice make it lag
Hi, new poster so sorry if this topic has been discussed before (tried a bit of searching first, but could not find anything).
I'm running the current pre-release of XBMC on a Windows PC. I have a Delta 1010LT Sound Card with multiple outputs. I have my 4:3 TV hooked up to an other output than my regular PC speakers.
If I start XBMC with my primary audio driver as output - no problem. If I then change the audio output to the channels which is routed to the TV - no problem. However if I start up XBMC with the audio output going to the TV channels - both video and music lag (plays a bit, then skips a bit).
Has anyone experienced anything similar? Know of a solution so that I do not have to change the audio outputs each time I start XBMC?
The same problem still remains. However I found out that the glitches returns after I've finished watching a video or listening to a full album (one song doesn't matter, or if I stop the video before it reaches the end).
