Here is what I used to do.. but no longer works with 9.11
Steps needed to get it all to work after you’ve connected it to the computer.
1. WinSCP has FTP and Putty. (freeware)
2. Get root access
3. Setup files
STEP 1
Download WinSCP (freeware)
http://winscp.net/eng/download.php
STEP 2
1- Open Putty (freeware)
2- type in the field "Hostname (or IP adress)" the IP of your xbmc then press open
3- it will ask you for name type: xbmc
4- then the actual password type: xbmc
then press enter (note it will seem like your not typing but you are)
5- you are loged in
6- Now type: sudo passwd root
7- Follow the instructions
Enter old password then new one
Your all done
STEP 3
First off some vim commands to understand what your doing
w Write (Save)
q Quit (Close)
wq Write and Quit. (Save and Close)
q! Force Quit (Close without saving changes)
To get started
3- it will ask you for name type: root
4- then the NEW password (note it will seem like your not typing but you are)
5- you are loged in
type: sudo rm /etc/lirc/hardware.conf
type: sudo pico /etc/lirc/hardware.conf
copy and paste ( if there is anything in the file delete everything then paste):
__________________________________________________ ________
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER=""
# If DEVICE is set to /dev/lirc and devfs is in use /dev/lirc/0 will be
# automatically used instead
DEVICE="/dev/lirc0"
MODULES="lirc_atiusb lirc_dev lirc_i2c"
# Default configuration files for your hardware if any
LIRCD_CONF="/etc/lirc/lircd.conf"
LIRCMD_CONF=""
type: ctrl x, y, then enter
type: sudo rm /etc/lirc/lircd.conf
type: sudo pico /etc/lirc/lircd.conf
# LIRCD configuration file for Xbox DVD Kit
# Marko Friedemann <mfr|bmx-chemnitz.de>
# brand: Microsoft
# model: Xbox DVD Remote
# supported devices: Xbox DVD Remote via xpad-ir driver
# comment: EXPERIMENTAL
begin remote
name XboxDVDDongle
bits 8
begin codes
SELECT 0x0b
UP 0xa6
DOWN 0xa7
RIGHT 0xa8
LEFT 0xa9
INFO 0xc3
9 0xc6
8 0xc7
7 0xc8
6 0xc9
5 0xca
4 0xcb
3 0xcc
2 0xcd
1 0xce
0 0xcf
DISPLAY 0xd5
BACK 0xd8
SKIP- 0xdd
SKIP+ 0xdf
STOP 0xe0
REVERSE 0xe2
FORWARD 0xe3
TITLE 0xe5
PAUSE 0xe6
PLAY 0xea
MENU 0xf7
end codes
end remote
press ctrl x, y , then enter.
Now you need to remove Xpad
type: sudo pico /etc/modprobe.d/blacklist.conf
(NOTE do not delete anything in this file just add)
press i then press down arrow until you reach the end of the writing.
now type:blacklist xpad
pres ctrl x, y , then enter
Close down Putty restart you xbmc system
All done should work
