Full Version: [LIVE] How to run XBOX DVD Dongle kit on my HTPC??
Hi, i'm a newbie with XBMC.
I've installed XBMC in my USB and i've connected an original xbox dvd dongle kit to my htpc with an usb adapter but doesn't work.
What should I do? I've read something about Lirc but i don't understand.
http://forum.xbmc.org/showthread.php?tid=62867
THANKS!
Can anybody help me, please?
have a read of this thread, it worked for me in the end
http://forum.xbmc.org/showthread.php?tid=63939
OMG , please explain me 2 little concepts.
XBMC live = ubuntu Huh
How to install lirc in XBMC live?
LET ME KNOW IF THIS WORKS
Steps needed to get it all to work after you’ve connected it to the computer.
1. WinSCP has FTP and Putty. (freeware)
2. Get root access
3. Setup files
STEP 1
Download WinSCP (freeware)
http://winscp.net/eng/download.php
STEP 2
1- Open Putty (freeware)
2- type in the field "Hostname (or IP adress)" the IP of your xbmc then press open
3- it will ask you for name type: xbmc
4- then the actual password type: xbmc
then press enter (note it will seem like your not typing but you are)
5- you are loged in
6- Now type: sudo passwd root
7- Follow the instructions
Enter old password then new one
Your all done
STEP 3
First off some vim commands to understand what your doing
w Write (Save)
q Quit (Close)
wq Write and Quit. (Save and Close)
q! Force Quit (Close without saving changes)
To get started
3- it will ask you for name type: root
4- then the NEW password (note it will seem like your not typing but you are)
5- you are loged in
type: sudo rm /etc/lirc/hardware.conf
type: sudo pico /etc/lirc/hardware.conf
copy and paste ( if there is anything in the file delete everything then paste):
__________________________________________________ ________
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="None"
REMOTE_MODULES="lirc_atiusb lirc_dev"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF=""
REMOTE_LIRCD_ARGS="-r"
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF="lircd.conf"
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="true"
START_LIRCMD=""
type: ctrl x, y, then enter
type: sudo rm /etc/lirc/lircd.conf
type: sudo pico /etc/lirc/lircd.conf
# this config file was automatically generated
# using lirc-0.8.3-CVS(default) on Fri Feb 8 09:34:50 2008
# brand: Microsoft Xbox DVD Receiever (also works with generic)
# remote control: Xbox remote or any remote using RCA DVD player codes
begin remote
name XboxDVDDongle
bits 8
eps 30
aeps 100
one 0 0
zero 0 0
gap 163983
toggle_bit_mask 0x0
begin codes
LEFT 0xA9
UP 0xA6
RIGHT 0xA8
DOWN 0xA7
SELECT 0x0B
1 0xCE
2 0xCD
3 0xCC
4 0xCB
5 0xCA
6 0xC9
7 0xC8
8 0xC7
9 0xC6
0 0xCF
MENU 0xF7
DISPLAY 0xD5
REWIND 0xE2
FFWD 0xE3
PLAY 0xEA
PAUSE 0xE6
STOP 0xE0
SKIP- 0xDD
SKIP+ 0xDF
TITLE 0xE5
INFO 0xC3
BACK 0xD8
end codes
end remote
press ctrl x, y , then enter.
Now you need to remove Xpad
type: sudo pico /etc/modprobe.d/blacklist.conf
(NOTE do not delete anything in this file just add)
press i then press down arrow until you reach the end of the writing.
now type:blacklist xpad
pres ctrl x, y , then enter
Close down Putty restart you xbmc system
All done should work
1,000.000 OF THANKS. I can't test it since Friday but i promise tell you if i do work it.
This thread was EXTREMELY useful! Thanks guys.
I recently got an Acer Revo set up with XBMC Live, and to keep in budget, didnt want to pop for a new remote/IR receiver. I had a spare XBOX DVD remote IR dongle to use, so I wired it to work with the REVO, but was having a hard time trying to figure out how to make it work on the config side.
I dug through a lot of info before I found this thread, which got me running in short time, so thanks again.
Bobbo
didn't work for me
