I use unetbootin to copy the image over on a FAT32 formated USB stick and have made the live-rw with toporesize. It boots fine into xbmc but everytime i try to edit xorg.conf its gone back to normal after next reboot.
Do i have to edit the syslinux.cfg parameters or?
Seems like nvidia-xconfig auto make a new xorg.conf everytime you reboot. Somebody most be aware of this.
I had this problem with Beta 1 ....
not an elegant solution, but after editing or copying the file
make it read only
this is with an installed version on a USB stick anyway
then on boot it can't copy over it
sudo chmod -rw /etc/X11/xorg.conf
I now have 24p working
Tried that but somehow it can still change it.
