Hey guys,
I have tried to install several scripts and plugings for XBMC-LIVE and I keep getting script errors. I tried to manually put NaviX into /usre/share/xbmc/scritps but this still led to an error.
Im I doing it wrong? has any one else had this issue?
not to much info there, please provide a debug log
newb2linux Wrote:Here is a link to the log file it generates.
http://pastebin.com/m1dbf72ca
I guess you have a permission failure
16:17:00 T:2825862000 M:1457115136 NOTICE: [Errno 13] Permission denied: '/home/xbmc/.xbmc/scripts/Common Scripts/Navi-X/favorites.plx'
Regards
Hans
Tried to add permissions on the folder didnt help ..
loads of scripts just wont run.. Any one able to get Navi-x working with Live ?
I just upgraded to b2 and am also having problems with scripts. (No problems with scripts using previous versions of live.) Not sure if this is related to your issue or not but it seems like scripts won't load, or take forever to load. Its one funny thing though it seems like if I initiate a command while attempting to run a script (i.e. volume up or volume down on my keyboard) It seems to function somewhat normal. But, I have to keep on initiating the command.
Wierd.
Only tested on 2 scripts (Navi-X and Aptitude) and both yield the same result.
I will try to post my log file later on.
is this a linux only issue?
i'm subscribed to this thread
