2009-12-14, 11:33
I found it a shame that the Confluence skin wasn't doing anything with the fanart during music playback, so here's a quick and short howto:
Add the following image control node to your MusicVisualisation.xml, which should be located in the directory 720p of the Confluence skin (on Windows: C:\Program Files (x86)\XBMC\skin\Confluence\720p)
Just insert it in front of the normal visualisation block. Once done and the visualisation switched to "none" in settings, you should see the fanart while playing music.
<allowoverlay>no</allowoverlay>
<controls>
<control type="image">
<description>visualisation background</description>
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<height>720</height>
<info>MusicPlayer.Property(Fanart_Image)</info>
</control>
<control type="visualisation" id="2">
<description>visualisation</description>
