Full Version: [REQUEST] More label controls
Pages: 1 2
is it posible to add more labels controls for use in lists. I.E. we have <label> & <label2> that we can assign for use with python scripts , etc., i would like to have more availble, so i do have to add them manually.
at the moment i use <label> & <label2>, but if i need more then i have to map ALL manually like this:
PHP Code:
<control type="label">
posx>0</posx>
posy>0</posy>
width>900</width>
height>45</height>
font>Font_RecentTitleLabel</font>
textcolor>ccffffff</textcolor>
aligny>center</aligny>
label fallback="-">[UPPERCASE][b]$INFO[Container(8001).ListItem.Label][/b][/UPPERCASE]</label>
control>
posx>0</posx>
posy>65</posy>
width>900</width>
height>30</height>
font>Font_RecentTitleLabel2</font>
textcolor>ccFFFFFF</textcolor>
label fallback="-">[UPPERCASE]$INFO[Container(8001).ListItem.Label2][/UPPERCASE]</label>
visible>Container(300).HasFocus(1)|Container(300).HasFocus(7)</visible>
control>
control type="textbox">
font>Font_WidgetPlot</font>
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
textcolor>c0FFFFFF</textcolor>
autoscroll delay="8000" time="2000" repeat="10000"></autoscroll>
label fallback="31414">$INFO[Window.Property(LatestEpisode.1.Plot)]</label>
visible>Container(8001).Row(0)</visible>
control>
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
label fallback="31414">$INFO[Window.Property(LatestEpisode.2.Plot)]</label>
visible>Container(8001).Row(1)</visible>
control>
etc......
but i would like to just use <label3> like this:
the list code could be like this:
PHP Code:
<item id="1">
label>$INFO[Window.Property(LatestEpisode.1.EpisodeTitle)]</label>
label2>$INFO[Window.Property(LatestEpisode.1.ShowTitle)] - $INFO[Window.Property(LatestEpisode.1.EpisodeNo)]</label2>
label3>$INFO[Window.Property(LatestEpisode.1.Plot)]</label3>
onclick>PlayMedia($INFO[Window.Property(LatestEpisode.1.Path)])</onclick>
thumb>$INFO[Window.Property(LatestEpisode.1.Thumb)]</thumb>
visible>!Control.IsVisible(87)</visible>
visible>Container(300).HasFocus(7)</visible>
item
PHP Code:
posx>0</posx>
posy>0</posy>
width>900</width>
height>45</height>
control>
posx>0</posx>
posy>65</posy>
width>900</width>
height>30</height>
control>
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
label fallback="31414">$INFO[Container(8001).ListItem.Label3]</label>
control
maybe we could have 10 availble for use ?
use properties
edit: unless you mean static lists, then i would agree.
i think in this case you can abuse <icon> to get a third label.
so change:
<label3>$INFO[Window.Property(LatestEpisode.1.Plot)]</label3>
to:
<icon>$INFO[Window.Property(LatestEpisode.1.Plot)]</icon>
and:
<label fallback="31414">$INFO[Container(8001).ListItem.Label3]</label>
to:
<label fallback="31414">$INFO[Container(8001).ListItem.Icon]</label>
Properties are the only thing we'll add. Not more labels. There's no doubt a trac ticket already for it (probably from Nuka1195 Smile )
Cheers,
Jonathan
Nuka1195 Wrote:use properties
could you explain for me please
i do have a patch, so probably a ticket for static lists.
ronnie, you may need ActualIcon
but if your filling from python (i'm a little confused) you already can use properties.
sorry, dont understand, is there no way i can add just one entry per item, then just call it as label within the fixedlist ? at the moment i have to do seperate labels ( one for every line of the list) so if the the list has 17 lines to it i have to use some thing like this (out side of the fixedlist code)
below is example of my curent code. it only show 3 line but i have 17 line to my fixedlist so this would be repeated for ALL 17 items. andthis use lots of code. and this is just for the tv epsidoe plot, i need to do this all other parts for music (album artists album name, review etc, etc) and this is a major problem for me, my skin is getting so bloated to try to work arround XBMC limtations, surly there a better way of coding this stuf. any ideas would be greatly accepted Smile
PHP Code:
<control type="group">
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
control>
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
control>
posx>0</posx>
posy>20</posy>
width>1400</width>
height>650</height>
label fallback="31414">$INFO[Window.Property(LatestEpisode.3.Plot)]</label>
visible>Container(8001).Row(2)</visible>
control
edit i also have i problem with FANART & THUMBS, if i set the fanart to <thumb>$INFO[Window.Property(LatestEpisode.3.Fanart)]</thumb> and the thumb to <icon>$INFO[Window.Property(LatestEpisode.3.Icon)]</icon> and then the with the corrisponding image controls it only allows one image either thumb or icon not both as a unique, is this a bug or just another limaitation ?
PHP Code:
<item id="1">
label>$INFO[Window.Property(LatestEpisode..EpisodeTitle)]</label>
thumb>$INFO[Window.Property(LatestEpisode.1.Fanart)]</thumb>
icon>$INFO[Window.Property(LatestEpisode.1.Thumb)]</icon>
item
PHP Code:
<control type="image">
            <include>
BackgroundVarsGlobal</include>
texture background="true">$INFO[Container(8001).ListItem.Icon]</texture>
control
PHP Code:
            <include>
texture background="true">$INFO[Container(8001).ListItem.Thumb]</texture>
control
got the above problem sorted in the end Smile
any furhter procgress on http://trac.xbmc.org/ticket/6692 making it into a svn ?
r26935 should do the trick.
jmarshall Wrote:r26935 should do the trick.
cheers Jonathan, i'll test once i can get a nightly with it in Smile
EDIT, i see you used a different method, could you tell me how to use it ?
I assume from the trac -
<property name="foo">value</property>
Hitcher Wrote:I assume from the trac -
hitcher where did you find that ?, i could not find track r26935
edit: i swear that was not there before lol
i cant get this work, can anyone help
in static list
PHP Code:
<property name="AlbumTitle">$INFO[Window.Property(LatestSong.1.Album)] - $INFO[Window.Property(LatestSong.1.Artist)]</property
outside of list
PHP Code:
<label>[UPPERCASE]$INFO[Container(8001).Window.Property(AlbumTitle)][/UPPERCASE]</label
also tried
PHP Code:
<label>[UPPERCASE]$INFO[Container(8001).ListItem.Property(AlbumTitle)][/UPPERCASE]</label
PHP Code:
<label>[UPPERCASE]$INFO[Container(8001).ListItem.AlbumTitle][/UPPERCASE]</label
this is working fine on my end:
in the <content> section of a static list:
Quote:<property name="FanartImage">$INFO[Window.Property(LatestMovie.1.Fanart)]</property>
outside the list:
Quote:<texture background="true">$INFO[Container(5044).ListItem.Property(FanartImage)]</texture>
Pages: 1 2
