Ive just ordered a Zotac Mag HD-ND01. Has anyone tried them yet with linux+xbmc?
Im getting it tomorrow so i will keep you posted.
hey! where did you ordered this MAG HD-ND01?
I really can't find it anywhere!!!
waiting for your answer!
Stefano
It available here in sweden since last week. There is a few retailers that has them.
There you go yeah.
So no-one has tested it yet? Should be the same card as their Zotac N330.
asbra
Check the reviews on the newegg link above. It looks like someone has it working. It looks like you had to edit xorg.conf to get it properly working.
Yeah got it running using the regular Asrock 330 Tutorial. Its for jaunty but it runs nicely on karmic.
It makes quite alot of noise but i like it.
I got it running using HDMI for both sound and picture.
Problem is the resolution.
I need to use 1360x768 instead of 1280x720 if I want pixelmapping.
That doesn't seem exactly trivial.
I am using a Samsung Q96( might have another name in the states).
Plasma 50".
I reccon one must use modelines to fix this.
Can anyone offer advice?
Did you want 1360x768?
Im running mine with 1360x768. Just changed the resolution using nvidia tool.
how you did it asbra? i'm having the same problem using HDMI, i'm using xbmc live 9.11 where is the nvidia tool? (i've no gnome gui installed)
thanks in advance,
