Full Version: Confluence video navigation question
Revealing my inexperience with the Confluence skin, I ask:
I begin playing a movie and press the ESC key on my (Win7) PC. The video now appears *inside* the Confluence main navigation structure.
How do I return to the video full screen?
In the previous default XBMC skin, there was a mini-menu available inside the navigation struction when video was playing. This mini menu had an option to full screen the video.
Also, is there a way to globally disable subtitles in Confluence?
Thanks for any help.
Tab.
Disable subs, then "set as default for all movies".
For the subtitles while a movie is playing bring up the on-screen settings guide. From there click subtitles and set to none. Then check 'set as default for all movies'.
Thanks very much guys. Sorry if the info is posted somewhere, but I couldn't find it. Really appreciate your help.
I too do not get the subtitle option in my menu.
BluScrnOdeth Wrote:I too do not get the subtitle option in my menu.
While a movie is playing move the mouse.
A menu will pop up--choose audio settings.
You'll find the subtitle options there.
