2014-02-20, 16:03
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
2014-02-21, 14:58
(2014-02-20, 16:03)somy Wrote: [ -> ]PPStream stops working, I got PPS4XBMC.exe has stopped working err, any suggestion?
pps4xbmc is not compatible withe ppstream version 3 and above. Please reinstall an earlier version.
2014-02-21, 15:11
(2014-02-21, 14:58)cmeng Wrote: [ -> ](2014-02-20, 16:03)somy Wrote: [ -> ]PPStream stops working, I got PPS4XBMC.exe has stopped working err, any suggestion?
Hi thank you!
Can you advice where can I find an older version?
2014-03-01, 01:11
Tudou and Youku are down again. When I click on the addon, no error messages and doesn't list any content.
2014-03-02, 16:17
(2014-02-21, 15:11)somy Wrote: [ -> ](2014-02-21, 14:58)cmeng Wrote: [ -> ](2014-02-20, 16:03)somy Wrote: [ -> ]PPStream stops working, I got PPS4XBMC.exe has stopped working err, any suggestion?
Hi thank you!
Please do an internet search for pps 2.7.x to install.
Just released a new version for qiyi. Please try.
Hi thank you!
2014-03-08, 05:55
(2014-03-02, 16:17)cmeng Wrote: [ -> ](2014-02-21, 15:11)somy Wrote: [ -> ](2014-02-21, 14:58)cmeng Wrote: [ -> ]pps4xbmc is not compatible withe ppstream version 3 and above. Please reinstall an earlier version.
Hi thank you!
Hi thank you!
Found the links for download the ppstream v2.7.0.1516.
http://www.ernesthan.com/?p=121
https://files.secureserver.net/0sQRNPYrXCznzZ
2014-04-08, 18:08
When using Tudou plugin, I can play single episode from a TV drama series, but when I want to play continuous, the plugin plays several seconds and hang.
Furthermore, I found the download speed is far slower then that from 千尋影視 app installed on IPAD. Is there any tricks to streaming faster?
2014-04-09, 06:14
The "Youku" and Tudou" Addons are not working in XBMC Gotham 13.0 Beta 3 (Android version).
Message "Cannot connect to server" pops up!
I noticed since Gotham 13.0 Alpha 9, these 2 addons show the above message error. Alpha 8 is fine.
Please help
Please help
2014-05-20, 10:56
The Tudou Plug-in
- the Language Option in the Configuration is not working. I selected "Cantonese" as preferred language, it still plays with "Mandarin", any solution?
2014-05-26, 00:41
(2014-05-20, 10:56)mycheetah Wrote: [ -> ]The Tudou Plug-inHow do you change from 'mandarin' to 'cantonese' on XBMC Tudou plug-in.
2014-05-27, 08:16
Any chance you can look into the 5ivdo plugin and see why under 电视直播。 Under 央视频道。 If I pick e.g. cctv-6, and pick "[cntv] cctv-6 电影", it doesn't work. They used to all work pretty well maybe a week, now they don't at all. Pretty much all the options have similar outcomes.
2014-06-02, 05:27
The Sohu and Youku Plug in stopped working for the Windows version.
Sohu Showed "script error"
Youku just can't play any video
No idea what's going on and please fix that. Thanks a lot.
Youku log
Sohu log
Youku log
11:24:44 T:5776 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
11:24:44 T:5776 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:24:44 T:5776 ERROR: XFILE::CFileCache::Open - failed to open source <http://f.youku.com/player/getFlvPath/sid/00_00/st/flv/fileid/03000112005367EA7866E1032DBBC75F24DE68-9865-0D4E-C109-C24257DCDD95?K=ef6c8d82c58252c42411d2c2>
Sohu log
11:29:27 T:5668 NOTICE: -->Python Interpreter Initialized<--
11:29:27 T:5668 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named ChineseKeyboard
File "C:\Users\dd\AppData\Roaming\XBMC\addons\plugin.video.sohuvideo\default.py", line 4, in <module>
import ChineseKeyboard
ImportError: No module named ChineseKeyboard
11:29:27 T:5776 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.sohuvideo/
11:29:27 T:5776 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.sohuvideo/) failed
11:29:27 T:3520 NOTICE: Thread BackgroundLoader start, auto delete: false
2014-06-03, 12:28
18:19:21 T:4372 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'group'
File "C:\Users\dd\AppData\Roaming\XBMC\addons\plugin.video.youku\default.py", line 566, in <module>
progList(name,id,page,genre,area,year,order)
File "C:\Users\dd\AppData\Roaming\XBMC\addons\plugin.video.youku\default.py", line 163, in progList
genrelist,arealist,yearlist = getList(listpage,id,genre,area,year)
File "C:\Users\dd\AppData\Roaming\XBMC\addons\plugin.video.youku\default.py", line 101, in getList
genrelist = re.compile('_g_([^_\.]*)[^>]*>([^<]+)</a>').findall(match.group(1))
AttributeError: 'NoneType' object has no attribute 'group'
18:19:21 T:4840 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youku/?area&genre&id=c_97&mode=1&name=%e7%94%b5%e8%a7%86%e5%89%a7&order=7&page=1&year
18:19:21 T:4840 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youku/?area&genre&id=c_97&mode=1&name=%e7%94%b5%e8%a7%86%e5%89%a7&order=7&page=1&year) failed
18:19:21 T:1484 NOTICE: Thread BackgroundLoader start, auto delete: false
18:19:23 T:3648 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:23 T:3648 NOTICE: -->Python Interpreter Initialized<--
18:19:24 T:2680 NOTICE: Thread BackgroundLoader start, auto delete: false
18:19:25 T:5044 NOTICE: Previous line repeats 1 times.
18:19:25 T:5044 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:25 T:5044 NOTICE: -->Python Interpreter Initialized<--
18:19:26 T:864 NOTICE: Thread BackgroundLoader start, auto delete: false
18:19:28 T:4944 NOTICE: Thread FileCache start, auto delete: false
18:19:29 T:4948 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:29 T:4948 NOTICE: -->Python Interpreter Initialized<--
18:19:30 T:1920 NOTICE: Thread BackgroundLoader start, auto delete: false
18:19:31 T:5844 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:31 T:5844 NOTICE: -->Python Interpreter Initialized<--
18:19:31 T:2796 NOTICE: Thread FileCache start, auto delete: false
18:19:42 T:4840 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
18:19:42 T:4840 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
18:19:42 T:4840 ERROR: XFILE::CFileCache::Open - failed to open source <http://f.youku.com/player/getFlvPath/sid/00_00/st/flv/fileid/03008014005379B4005DEF03BAF2B1CC972784-5F65-15EF-C1A8-5E850EEF10D8?K=6057bb0ff582b36d2411d31e>
18:19:42 T:6072 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:42 T:6072 NOTICE: Previous line repeats 2 times.
18:19:42 T:6072 NOTICE: -->Python Interpreter Initialized<--
18:19:42 T:5812 NOTICE: -->Python Interpreter Initialized<--
18:19:42 T:5536 NOTICE: -->Python Interpreter Initialized<--
18:19:43 T:1548 NOTICE: Thread FileCache start, auto delete: false
18:19:43 T:5700 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:43 T:5700 NOTICE: -->Python Interpreter Initialized<--
18:19:44 T:3144 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:44 T:3144 NOTICE: -->Python Interpreter Initialized<--
18:19:44 T:4548 NOTICE: Thread LanguageInvoker start, auto delete: false
18:19:45 T:4548 NOTICE: Previous line repeats 1 times.
18:19:45 T:4548 NOTICE: -->Python Interpreter Initialized<--
18:19:45 T:6020 NOTICE: -->Python Interpreter Initialized<--
18:19:54 T:4840 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
18:19:54 T:4840 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
18:19:54 T:4840 ERROR: XFILE::CFileCache::Open - failed to open source <http://f.youku.com/player/getFlvPath/sid/00_00/st/flv/fileid/03008014005379B4005DEF03BAF2B1CC972784-5F65-15EF-C1A8-5E850EEF10D8?K=e84ba735df83145e28299748>
18:20:05 T:4840 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
18:20:05 T:4840 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
18:20:05 T:4840 ERROR: XFILE::CFileCache::Open - failed to open source <http://f.youku.com/player/getFlvPath/sid/00_00/st/flv/fileid/03008014005379B4005DEF03BAF2B1CC972784-5F65-15EF-C1A8-5E850EEF10D8?K=7f66fd2cfb1a9adf261db533>
Again, Youku still have problems in playing videos
2014-06-07, 17:51
Any solution to fix the Youku plugin not being able to play any videos?
2014-06-12, 06:40
pptv 1.2.4 by Uranus Zhou doesn't seem to work anymore.
Whatever I choose it states, 无法获取视频地址。
