2014-06-22, 06:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
2014-06-22, 07:33
(2014-06-22, 06:43)taxigps Wrote: [ -> ]update 优酷视频(YouKu) to 2.2.0 - fixed: can't play video because site change
How can I update it? Thank you
2014-06-22, 08:44
2014-06-22, 22:56
(2014-06-22, 08:44)taxigps Wrote: [ -> ](2014-06-22, 07:33)tigertam Wrote: [ -> ](2014-06-22, 06:43)taxigps Wrote: [ -> ]update 优酷视频(YouKu) to 2.2.0 - fixed: can't play video because site change
will auto upgrade from xbmc-addon-chinese
Thank you very much, But look like it has buffering problem.
2014-06-23, 04:09
(2014-06-22, 22:56)tigertam Wrote: [ -> ](2014-06-22, 08:44)taxigps Wrote: [ -> ](2014-06-22, 07:33)tigertam Wrote: [ -> ]How can I update it? Thank you
Ya, I experienced serious buffering problem every couple of seconds.
2014-06-23, 04:11
New install file: repository.xbmc-addons-chinese-1.0.2.zip(New site)
Changes:
1. Move from code.google.com to github.com for access better in China.
2. Change to use compressed zip file for download and install addon from repo faster.
Changes:
2014-06-28, 01:26
(2014-06-23, 04:11)taxigps Wrote: [ -> ]New install file: repository.xbmc-addons-chinese-1.0.2.zip(New site)
Changes:
Thank you
2014-07-17, 15:33
I need some help. I tried installing all add-on but keep getting an error every time i try opening a video. For example, with PPTV it says can't play video, or with PPS i just goes to my desktop and then a crash message comes up saying PPSxbmc (or something like that) failed to open. With CNTV, it just goes to a black screen saying loading but nothing happens.
None of the add-on works for me!! Is there any other steps I need to do? Do I need to install another program?? Please help!
2014-07-21, 10:39
So I checked the http address that the pptv app tries to connect to.
If e.g. I try to connect to the Beijing tv station, it uses this address.
"http://web-play.pptv.com/web-m3u8-300166.m3u8?type=m3u8.web.pad"
If I open up that link using a web browser, it says
if I try to ping live2.jump.idc.pplive.cn, it doesn't seem to exist.
If I change the address to "http://web-play.pptv.com/web-m3u8-300166.m3u8?type=ppbox", a m3u8 file is generated.
e.g.
The problem is "type=ppbox" is wrong, and it should be "type=m3u8.web.pad". Once I change the type, I can use the generated .m3u8 file under xbmc.
I don't know enough exactly what's going on in the default.py file to make some quick edits, but can someone look into it, and simply query instead using type=ppbox, and then replace type=ppbox with type=m3u8.web.pad in the generated m3u8 file? Seems like a simple fix for someone who knows what they are doing.
"ERROR:live dt failed:http://live2.jump.idc.pplive.cn:8080/live2/d005a79e2c474848a7b316f6f87cecee?playtag=true&key=true&kk=&pre=ikan&type=m3u8.web.pad&chid=300166&&playtag=true"
e.g.
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1, BANDWIDTH=400000
http://117.135.161.35:80/live/5/30/d005a79e2c474848a7b316f6f87cecee.m3u8?pre=ikan&type=ppbox&chid=300166&k=
http://112.117.210.22:80/live/5/30/d005a79e2c474848a7b316f6f87cecee.m3u8?pre=ikan&type=ppbox&chid=300166&k=
2014-07-23, 08:55
(2014-07-21, 10:39)Huuh Wrote: [ -> ]So I checked the http address that the pptv app tries to connect to.
Code:"ERROR:live dt failed:http://live2.jump.idc.pplive.cn:8080/live2/d005a79e2c474848a7b316f6f87cecee?playtag=true&key=true&kk=&pre=ikan&type=m3u8.web.pad&chid=300166&&playtag=true"
e.g.
Code:#EXTM3U
have test, the method only works for live channels.
2014-07-24, 09:32
(2014-07-23, 08:55)taxigps Wrote: [ -> ]have test, the method only works for live channels.
You're right, not sure how watching the other videos work.
Do you think you can get in contact with the 5vido author? Perhaps add live channel servers to their list using this method? Often times in the US, PPTV servers work better than the listed sohu live channel servers. Also there's more PPTV live channels than Sohu live channels.
2014-07-24, 16:45
(2014-07-24, 09:32)Huuh Wrote: [ -> ](2014-07-23, 08:55)taxigps Wrote: [ -> ]have test, the method only works for live channels.
fixed live channels in PPTV视频. update to 1.2.5. thanks.
2014-07-25, 07:53
(2014-07-24, 16:45)taxigps Wrote: [ -> ](2014-07-24, 09:32)Huuh Wrote: [ -> ](2014-07-23, 08:55)taxigps Wrote: [ -> ]have test, the method only works for live channels.
thanks a lot!
edit: I tried the update. I seem to be getting this error. whenever I try streaming a channel.
01:58:06 323.347534 T:2717766736 NOTICE: http://web-play.pptv.com/web-m3u8-300166...type=ppbox
01:58:06 323.368561 T:2717766736 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeEncodeError'>
Error Contents: 'ascii' codec can't encode characters in position 58-61: ordinal not in range(128)
File "/storage/.xbmc/addons/plugin.video.pptv/default.py", line 821, in <module>
playVideo(name, url, thumb)
File "/storage/.xbmc/addons/plugin.video.pptv/default.py", line 745, in playVideo
with open(m3u, "w") as f:
UnicodeEncodeError: 'ascii' codec can't encode characters in position 58-61: ordinal not in range(128)
edit 2: that error appears when I use the raspberry pi. It doesn't appear when I use my laptop. Any clues what could be going on?
edit 3: I haven't programmed anything for more than 10 years, so my coding skills are bad. I change the code so it says,
def playVideo(name, url, thumb):
ppurls = []
# if live page without video link, try to get video link from search result
if re.match('^http://live\.pptv\.com/list/tv_program/.*$', url):
url = GetPPTVSearchList(PPTV_SEARCH_URL + urllib.quote_plus(name), name)
if len(url) > 0:
quality = int(__addon__.getSetting('movie_quality'))
ppurls = GetPPTVVideoURL(url, quality)
if len(ppurls) > 0:
playlist = xbmc.PlayList(1)
playlist.clear()
if os.path.isdir(__temp__):
shutil.rmtree(__temp__.encode("utf-8")) [b]*** change code here ***[/b]
xbmc.sleep(100)
os.mkdir(__temp__)
for i in range(0, len(ppurls)):
data = GetHttpData(ppurls[i])
print ppurls[i]
data = data.replace('type=ppbox', 'type=m3u8.web.pad')
m3u = os.path.join( __temp__, "%s%d.m3u" % (name.decode("utf-8"),i))
with open(m3u.encode("utf-8"), "w") as f: [b]*** changed code here ***[/b]
f.write(data)
f.close()
title = name + ' ' + PPTV_TTH + ' ' + str(i + 1) + '/' + str(len(ppurls)) + ' ' + PPTV_FIELD
liz = xbmcgui.ListItem(title, thumbnailImage = thumb)
liz.setInfo(type = "Video", infoLabels = { "Title" : title })
playlist.add(m3u, liz)
xbmc.Player().play(playlist)
else:
xbmcgui.Dialog().ok(__addonname__, PPTV_MSG_GET_URL_FAILED)
it seems to work now with the raspberry pi. Does this seem correct to you?
2014-07-25, 08:36
(2014-07-25, 07:53)Huuh Wrote: [ -> ]try to change line 744 as:(2014-07-24, 16:45)taxigps Wrote: [ -> ](2014-07-24, 09:32)Huuh Wrote: [ -> ]You're right, not sure how watching the other videos work.
thanks a lot!
m3u = os.path.join( __temp__, u"%s%d.m3u" % (name.decode("utf-8"),i))
2014-07-25, 20:56
(2014-07-25, 08:36)taxigps Wrote: [ -> ](2014-07-25, 07:53)Huuh Wrote: [ -> ]try to change line 744 as:(2014-07-24, 16:45)taxigps Wrote: [ -> ]fixed live channels in PPTV视频. update to 1.2.5. thanks.
thanks a lot!
when I take out my edits, and put that line instead in, I get this error.
14:55:23 40440.652344 T:2719777872 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xe4 in position 1: ordinal not in range(128)
File "/storage/.xbmc/addons/plugin.video.pptv/default.py", line 737, in playVideo
shutil.rmtree(__temp__)
File "/home/neil/projects/OpenELEC.tv/build.OpenELEC_Helix-RPi.arm-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/shutil.py", line 239, in rmtree
File "/home/neil/projects/OpenELEC.tv/build.OpenELEC_Helix-RPi.arm-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/posixpath.py", line 71, in join
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe4 in position 1: ordinal not in range(128)
