Full Version: [RELEASE] Project xbmc-addons-chinese (Chinese addons for Kodi)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
Hi, the PPTV plugin is having trouble again. It seems like it's adding in an extra "}" into the address.
E.g. when I look at the log file the address is
"http://web-play.pptv.com/web-m3u8-300166}.m3u8?type=m3u8.web.pad&kk=872e431765fc940c9c770a77cff2de55-6a04-54589677&o=v.pptv.com"
As you can see 300166 and .m3u8 is an extra "}"
If you can get rid of it, the address gets a valid .m3u8 back, and I think PPTV should work again for live tv streams.
It's working already :-) Great! Was worried for a while.
(2014-11-04, 10:30)Huuh Wrote: [ -> ]Hi, the PPTV plugin is having trouble again. It seems like it's adding in an extra "}" into the address.
updated to version 1.2.7, thanks!
How come all of a sudden I have cache being filled up in Gotham when streaming? Don't have this problem before. Any changes with the plugin? And seems it's slow to buffer on LETV.
Can anyone get Tudou to work?
I load into it and there is nothing to view. I believe the first item is for filtering, but it never comes back with anything either.
Youku seems to have a lot of trouble buffering. Also a lot of times they are missing videos underneath the video.
Does anyone know how to get this to run under Helix.
I tried to install the ppstream addon but I get a 'script error' when I run it.
FYI this was on a rikomagic 902II android box
TIA
Rob
Having trouble with the PPTV plugin again. Sometimes it works, but it's fairly seldom. I keep getting this error. I'm not sure if anyone else is having this error.
01:52:35 271857.312500 T:2527147072 NOTICE: GetHttpData Error: http://live.pptv.com/api/tv_list?area_id=2
01:52:35 271857.312500 T:2527147072 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/storage/.kodi/addons/plugin.video.pptv/default.py", line 815, in <module>
listVideo(name, url, GetPPTVVideoList(url))
File "/storage/.kodi/addons/plugin.video.pptv/default.py", line 340, in GetPPTVVideoList
pptmp = json.loads(tmp)
File "/home/neil/projects/OpenELEC.tv/build.OpenELEC-RPi.arm-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads
File "/home/neil/projects/OpenELEC.tv/build.OpenELEC-RPi.arm-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode
File "/home/neil/projects/OpenELEC.tv/build.OpenELEC-RPi.arm-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
ValueError: No JSON object could be decoded
01:52:35 271857.593750 T:3041370112 ERROR: GetDirectory - Error getting plugin://plugin.video.pptv/?mode=videolist&name=%e5%85%a8%e5%9b%bd%e7%94%b5%e8%a7%86%e5%8f%b0&url=http%3a%2f%2flive.pptv.com%2flist%2ftv_list
01:52:35 271857.593750 T:3041370112 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.pptv/?mode=videolist&name=%e5%85%a8%e5%9b%bd%e7%94%b5%e8%a7%86%e5%8f%b0&url=http%3a%2f%2flive.pptv.com%2flist%2ftv_list) failed
When I try going to this webpage using a web browser, it seems to work. http://live.pptv.com/api/tv_list?area_id=2 When I click on a link under that webpage, I'm not sure if they are working correctly, perhaps due to not being parsed correctly.
I was installing/adding TVBdo.com to my PC for the first on XBMC and got a message stating that it was not compatible. Can someone assist
Any hope of getting the LETV plugin to work again? I believe it uses flvcd.com to get the links but that doesn't work anymore with letv, and wants you to download their software instead.
I second the motion. HOpe to get LETV working.
(2014-12-05, 06:34)jang430 Wrote: [ -> ]I second the motion. Hope to get LETV working.
Have tried for many days, still unsuccessful. Facing problem to debug as Letv site has denied video playback outside china.
Tried the following new site to fetch the video link but still not successful.
"http://www.flvxz.com/getFlv.php?url=" + base64.b64encode(url)
Still working on it. Any good suggestions.
(2014-11-16, 20:52)blackmambahk Wrote: [ -> ]Does anyone know how to get this to run under Helix.
TIA
Rob
ppstream version 2.2.14 is tested working under Kodi 14.0 Helix.
What are your system OS and ppstream version?
Please also refer to the following site for more info on ppstream installation.
https://github.com/taxigps/xbmc-addons-chinese
(2014-11-19, 08:58)Huuh Wrote: [ -> ]Having trouble with the PPTV plugin again. Sometimes it works, but it's fairly seldom. I keep getting this error. I'm not sure if anyone else is having this error.
PPTV视频 updated to 1.2.8 by Uranus Zhou - nocwat at gmail dot com
(2014-12-15, 05:00)taxigps Wrote: [ -> ]PPTV视频 updated to 1.2.8 by Uranus Zhou - nocwat at gmail dot com
Was the tv channels list taken away? It doesn't appear in the menu anymore.
edit: nevermind, it's now appearing, but majority of the times when I click on 全国电视台, it doesn't work or takes a very long time to get working. The other sections that were reenabled in the latest updates work perfectly fast.
anyone know if with LEtv plugins, etc, you can download episodes to xbmc machine?
