is cctvlive.exe open source? Where can I find the source code? I'm still having issue with controls no matter what keys I map to. Thanks!
Does anyone know if any of these Chinese addons work on XBMC for the original xbox?
If not, does anyone knows how I could modify them to work to with the original xbox?
Thanks in advance.
Hi, could someone please help me with plugin.video.tencent - Online video from v.qq.com (Chinese)? I have installed it but the script fails when I select a programme to view. Is there something else I need to install?
aunghtain Wrote:is cctvlive.exe open source? Where can I find the source code? I'm still having issue with controls no matter what keys I map to. Thanks!
See below link for solution if you are using Microsoft Windows:
http://forum.xbmc.org/showpost.php?p=945...stcount=80
You may need to re-launch the keymapSet.exe, and re-enter the keycode after the above setup. Place the cursor on the keycode field, and press the desired keypad button to input a new keycode.
talkingbollox Wrote:Hi, could someone please help me with plugin.video.tencent - Online video from v.qq.com (Chinese)? I have installed it but the script fails when I select a programme to view. Is there something else I need to install?
I think the video playback is not allowed outside China. Following is the message while accesing the tencent video link from Singapore.
http://vv.video.qq.com/geturl?otype=xml&...d1iXfsAdjF
<?xml version="1.0" encoding="utf-8" standalone="no" ?>
- <root>
<em>80</em>
<msg>ip is not authorized</msg>
<s>f</s>
</root>
Playback using downloaded player giving error code 5014:
"QQLive坚持为用户提供正版高清的视频,由于版权方的不同,部分内容只在特定地区有播放权益,敬请理解。建议您去QQLive查看其他精彩内容。"
Tudou plug-in error, need help.
Thanks in advanced.
cmeng Wrote:=========================================================
I was also facing the same problem, but eventually found the cause and solution. The main reason is that the cctvlive.exe is written to execute under non-Unicode Chinese-PRC OS environment. On a non-PRC OS environment (where most Asian are using i.e. English), the OS input fails to handle and to pass in the proper Chinese-PRC coded keypress for the cctvlive.exe. So on the non-PRC OS environment, you need to do the following settings:
On Windows 7 (similar for Windows XP):
Go to “Control Panel” => “Region and Language” => Select Tab “Administrative”
Click button “Change system locale” to “Chinese (Simplified, PRC)”
and restart the machine as instructed.
After this, all the program written for Chinese-PRC OS should work, including keymapset.exe and cctvlive.exe in CNTV-Live plug-in.
Use Shift-Tab button to toggle and select CNTV window before it accepts input. Will face a bit of difficulty using mouse click to select the CNTV window.
added to description of plugin.video.cntv-live, thx
I'm running the latest stable XBMC (Linux), because GIT compiling isn't feasible. I miss SVN already...
The Tudou, and Youku, plugins fail to install with a script error.
Is there something additional I need?
chimo1 Wrote:Tudou plug-in error, need help.
Thanks in advanced.
I have actually patched up the plugin and it will now play the videos that I wanted to watch. I was hoping to attach the patched "default.py" file here but I did not see a way to attach a file in a post. Any suggestions?
cmeng Wrote:See below link for solution if you are using Microsoft Windows:
Thank you for your reply. After I set my system locale to chinese, it works, but only after I alt-tab to choose the external player. Is it possible to make it so that it gets focused and no longer need to alt-tab choose it? Also, can you make it so that the external player will quit on media-stop key as well? I'm using remote control and there is no way to enter 'x'. Thank you.
