Full Version: [All Platforms] - New TVDB BUG
All,
Looks like a bug has developed across several platforms for scraping TV shows from TheTVDB.
The issue is that XBMC will only scan the first two episodes from a file naming convention using thetvdb.
For example, Files that have failed look like:
STARTREK_s03e01e02e03e04.ISO
STARTREK_s03e05e06e07e08.ISO
In these two files, only the first two episodes are being scraped (e01e02 & e05e06). The latter two (or more) in the file name are ignored.
Please see:
http://forum.xbmc.org/showthread.php?p=4...post459797
http://forum.xbmc.org/showthread.php?tid=64256
I was able to verify that this issue exists with a fresh download of 9.11-beta2 r25483
As pointed out in the threads you've linked to, its already fixed in svn.
And on a side issue has nothing to do with TheTVDB.
thanks prae5,
Can you (or anyone on this mailer) help me to better understand...
Are you suggesting that I download from http://www.sshcs.com/xbmc/ ?
I had downloaded the SVN update files from that site, and that is when the issue seemed to develop.
Should I download the complete version there and try that?
Is there a different site that you recommend? What SVN resolved this?
Sorry for being dense, but I could appreciate a bit more info.
Stop spamming multiple threads with the same problem.
http://trac.xbmc.org/timeline
Fixed in 25663 - http://trac.xbmc.org/changeset/25663
