2009-12-17, 08:28
Does anyone managed to get an ASrock Ion330HT connected to an N wifi Access point?
The hardware supports the N standard, but when I connect to my AP it only connects on G when I switch my AP to N only it does not connect.
My guess is that it's the driver, but I can't get hold on which card is in this machine.
Anyone who can tell me if I need to update the Wifi driver and if so which one?
And how to force it on to the N standard
This is what my dmesg regarding to WLAN says :
Any help or pointing me in the right direction would be great !
[ 8.138527] cfg80211: World regulatory domain updated:
[ 8.138536] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.138545] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.138551] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.138558] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.138564] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.138571] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.691871] HDA Intel 0000:00:08.0: power state changed by ACPI to D0
[ 8.692961] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22
[ 8.692977] HDA Intel 0000:00:08.0: PCI INT A -> Link[LAZA] -> GSI 22 (level, low) -> IRQ 22
[ 8.693075] HDA Intel 0000:00:08.0: setting latency timer to 64
[ 8.696706] ACPI: PCI Interrupt Link [LN3A] enabled at IRQ 19
[ 8.696720] alloc irq_desc for 19 on node -1
[ 8.696727] alloc kstat_irqs on node -1
[ 8.696746] ath9k 0000:02:00.0: PCI INT A -> Link[LN3A] -> GSI 19 (level, low) -> IRQ 19
[ 8.696764] ath9k 0000:02:00.0: setting latency timer to 64
[ 8.746452] ath: EEPROM regdomain: 0x60
[ 8.746459] ath: EEPROM indicates we should expect a direct regpair map
[ 8.746467] ath: Country alpha2 being used: 00
[ 8.746471] ath: Regpair used: 0x60
[ 8.948026] phy0: Selected rate control algorithm 'ath9k_rate_control'
[ 8.949861] Registered led device: ath9k-phy0::radio
[ 8.949933] Registered led device: ath9k-phy0::assoc
[ 8.949998] Registered led device: ath9k-phy0::tx
[ 8.950065] Registered led device: ath9k-phy0::rx
[ 8.950120] phy0: Atheros AR9285 MAC/BB Rev:2 AR5133 RF Rev:e0: mem=0xfa2e0000, irq=19
[ 9.416537] hda_codec: Unknown model for ALC889A, trying auto-probe from BIOS...
[ 9.432669] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:08.0/input/input5
[ 9.873587] ADDRCONF(NETDEV_UP): wlan0: link is not ready
