Full Version: Music Playblack Info Banner
I can't find how to keep the info banner (down the visualization) permanently on screen during music playback.
My system :
9.11b2 (from repos)
Skin Confluence
Control : mouse, for the moment
Is that even possible ?
just push I on the keyboard once to bring it up then it will always be up
Any way to make it stay on by default?
Thanks Very much for the theme btw! Smile
Jezz_X Wrote:just push I on the keyboard once to bring it up then it will always be up
Can it be done with only a remote?
DannyBres Wrote:Any way to make it stay on by default?
Sure do exactly what I said manually turn it on and leave it on and it should always be on every time you run xbmc until you turn it off again
rcrh Wrote:Can it be done with only a remote?
depends if your remote has a button mapped to showinfo
Thanks for reply
I found Info button, but the banner hide itself after a few seconds
I got asrock ion 330-ht, so remote control don't work for the moment.
I use mouse to control xbmc, it's a bit annoying to press i and the keyboard.
A skin option to get this function permanently should be easy for devs. No ?
do you have it working? I'm stumbling with the same problem.
I have the asrock remote working, bu when i push a button the info will pop up but it will not stay there.
works fine for me just hit i on the keyboard and it stays on! Smile
Is there a way to make the OSD stay permanently while playing music in full screen visualisation (So like the I did for info)
Kind Regards
From what I understand, if you create an advancedsettings.xml file in the userdata folder with the following contents:
<advancedsettings>
<songinfoduration>0</songinfoduration>
</advancedsettings>
That should get the info to stay up permanently.
What I want to know is how to disable the screen when the song changes and only make it pop up if I press INFO...
Can anyone help me on this, thx!?
