Full Version: [Windows] XBMC 9.11 Beta 2 Does not Shutdown PC
Hello all
Using XBMC 9.11 Beta 2.
I've noticed that, when ever I select the option to exit XBMC and Shutdown the PC, only XBMC exits but it does not shutdown the PC.
Here is the log of it if needed http://pastebin.com/m38b2a01
Thanks In Advance
Regards
Migs
Problem has been solved by heril on IRC.
Thanks anyway!
By default, the System Settings -> System -> Power Saving -> Shutdown function is set to quit and not Shutdown.
Changing it to Shutdown solves the problem.
