Full Version: Question about 1024x1080 (yes that way) resolution and poor text quality
So I am new to the XBMC community, running [live] with the Camelot 1 RC on an Acer Revo 1600. All of my menu texts look like garbage. Its uber pixalated, etc.
I have a Hitachi 42HSD69 Plasma TV. According to Hitachi, the pixel display is 1024x1080 (not 1080x1024). I tried all of the defaults to no avail.
I've been reading around on the site and there is discussion about getting the monitor settings from PowerStrip and importing them. So I ran MonInfo and got this chunk.
Monitor
Model name............... FPD TV
Manufacturer............. Hitachi
Plug and Play ID......... HTC0083
Serial number............ n/a
Manufacture date......... 2006, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7,2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,651 - Ry 0,335
Green chromaticity....... Gx 0,218 - Gy 0,717
Blue chromaticity........ Bx 0,146 - By 0,052
White point (default).... Wx 0,268 - Wy 0,283
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-50kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 90MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
1024 x 768p at 60Hz - VESA
640 x 480p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27,000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Detailed timing #4....... 1440x480i at 60Hz (16:9)
CE video data (timings supported)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
NB: NTSC refresh rate = (Hz*1000)/1001
So I don't see anywhere in regards to my "listed" resolution. Am I just high? Is it something else thats causing my font to look shitty (tried 4 different short length HDMI cables)
Am I also just being an idiot about this pixel resolution?
Any help is appreciated.
