I'm running an Acer Aspire Revo 3610 with Live 9.11 RC1.
When I access the command line (ctl+alt+F6), and then return to XBMC (ctl+alt+F7), there is a smaller version of the mouse cursor in the center of the screen that doesn't move (almost like it's part of the picture). I still have the mouse cursor that I can move around, but this "copy" remains in the center through all menu screens, movies, etc. The only way to get rid of it is to suspend and wake the unit or to reboot.
Any ideas?
Luigi-
As always... You're awesome.
Thanks for the help.
htrodscott,
what did you do with the cursor? Where do I have to search for HWCursor=off?
skmichi Wrote:htrodscott,
sudo nano /etc/X11/xorg.conf
Then look for the [Device]-section and add the following line to it:
Option "HWCursor" "off"
Thanks x5nder,
You beat me to it. skmichi, do what he said. It fixed my annoying cross in the center of my screen.
This forum is great. So many helpful people.
Hi Luigi,
I'm new to linux and xbmc. I had this problem in my Lucid + Xbmc on my new Zacate AMD E-350. Your solution helped me remove the second cursor BUT
today after updating to Catalyst Control Centre 11.10 its back and the X11/xorg file still has HWcursor as "off".
Cannot remove it the cursor.
Please help. Its so annoying. No clue:confused2:
Hi Luigi,
Just found out that when there is an update of Catalyst Control Centre we need to manualy create a new xorg config file and needs to force use the same. -
http://wiki.cchtml.com/index.php/Ubuntu_....conf_file
Not sure if this conflicts the earlier xorg config file and do something. Like i said i'm new to linux and xbmc and so i do not have any clue what this is all about.
Would be grateful if you could just show me the steps to say check /remove/update or change whatever to remove the cursor.
