2009-12-19, 16:45
When selecting "Remove from library" from the context menu in the tv library, tv episodes which reside inside a rar archive do not get removed. I can delete the episode from the Video files view (i.e. File manager).
Episodes which are not archived, e.g. .avi or .mkv files, get deleted just fine when removing from the library.
Version info:
Platform: Windows build 7600. Built on Dec 18 2009 (SVN:25820, compiler 1500)
I believe the aproperiate entries from the debug log are:
From the library:
From file manager:
Tusse.
Version info:
From the library:
15:24:07 T:3860 M:1065496576 ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\Username\AppData\Roaming\XBMC\userdata\Thumbnails\Video\f\ffffffff.tbn
15:24:07 T:3860 M:1065496576 ERROR: XFILE::CFile::Delete - Error deleting file special://masterprofile/Thumbnails/Video/f/ffffffff.tbn
15:24:08 T:3860 M:1065619456 DEBUG: FileManager::DeleteItem: 1x04. Ladies in Red
15:24:08 T:3860 M:1065619456 INFO: Loading skin file: DialogYesNo.xml
15:24:08 T:3860 M:1065615360 DEBUG: Load DialogYesNo.xml: 1.44ms
15:24:08 T:3860 M:1065615360 DEBUG: ------ Window Init (DialogYesNo.xml) ------
15:24:08 T:3860 M:1065615360 DEBUG: Alloc resources: 0.02ms (0.00 ms skin load)
15:24:09 T:3860 M:1067053056 DEBUG: SDLKeyboard: scancode: 75, sym: 276, unicode: 0, modifier: 0
15:24:09 T:3860 M:1067053056 DEBUG: CApplication::OnKey: 61477 pressed, action is 1
15:24:11 T:3860 M:1067065344 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 0
15:24:11 T:3860 M:1067065344 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
15:24:12 T:3860 M:1067065344 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
15:24:12 T:3860 M:1068302336 INFO: Loading skin file: DialogProgress.xml
15:24:12 T:3860 M:1068322816 DEBUG: Load DialogProgress.xml: 1.69ms
15:24:12 T:3860 M:1068322816 DEBUG: ------ Window Init (DialogProgress.xml) ------
15:24:12 T:3860 M:1068322816 DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
15:24:12 T:3860 M:1067012096 DEBUG: FileManager: delete rar://Z%3a%5cVideo%5cTV%5cTV1%5cThe%20Mentalist%5cThe%2eMentalist%2eS01%2eDVDRip%2eXviD%2dREWARD%5cThe%2eMentalist%2eS01E04%2eDVDRip%2eXviD%2dREWARD%5cthe%2ementalist%2es01e04%2edvdrip%2exvid%2dreward%2erar/the.mentalist.s01e04.dvdrip.xvid-reward.avi
15:24:12 T:3860 M:1067012096 ERROR: XFILE::CFile::Delete - Error deleting file rar://Z%3a%5cVideo%5cTV%5cTV1%5cThe%20Mentalist%5cThe%2eMentalist%2eS01%2eDVDRip%2eXviD%2dREWARD%5cThe%2eMentalist%2eS01E04%2eDVDRip%2eXviD%2dREWARD%5cthe%2ementalist%2es01e04%2edvdrip%2exvid%2dreward%2erar/the.mentalist.s01e04.dvdrip.xvid-reward.avi
15:24:12 T:3860 M:1067712512 DEBUG: CGUIMediaWindow::GetDirectory (videodb://2/2/76/-1/)
From file manager:
15:25:37 T:3860 M:1077428224 DEBUG: FileManager::DeleteItem: The.Mentalist.S01E04.DVDRip.XviD-REWARD
15:25:37 T:3860 M:1077428224 INFO: Loading skin file: DialogYesNo.xml
15:25:37 T:3860 M:1077424128 DEBUG: Load DialogYesNo.xml: 1.57ms
15:25:37 T:3860 M:1077424128 DEBUG: ------ Window Init (DialogYesNo.xml) ------
15:25:37 T:3860 M:1077424128 DEBUG: Alloc resources: 0.02ms (0.00 ms skin load)
15:25:38 T:3860 M:1075355648 DEBUG: SDLKeyboard: scancode: 75, sym: 276, unicode: 0, modifier: 0
15:25:38 T:3860 M:1075355648 DEBUG: CApplication::OnKey: 61477 pressed, action is 1
15:25:38 T:3860 M:1075404800 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 0
15:25:38 T:3860 M:1075404800 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
15:25:39 T:3860 M:1075404800 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
15:25:39 T:3860 M:1076674560 INFO: Loading skin file: DialogProgress.xml
15:25:39 T:3860 M:1076699136 DEBUG: Load DialogProgress.xml: 1.64ms
15:25:39 T:3860 M:1076699136 DEBUG: ------ Window Init (DialogProgress.xml) ------
15:25:39 T:3860 M:1076699136 DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
15:25:39 T:3860 M:1075376128 DEBUG: FileManager, processing folder: Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\Sample\
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.nfo
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r00
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r01
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r02
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r03
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r04
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r05
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r06
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r07
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r08
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r09
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r10
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r11
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r12
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r13
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r14
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r15
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r16
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r17
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r18
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r19
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r20
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r21
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r22
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.r23
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.rar
15:25:39 T:3860 M:1075376128 DEBUG: -- Z:\Video\TV\TV1\The Mentalist\The.Mentalist.S01.DVDRip.XviD-REWARD\The.Mentalist.S01E04.DVDRip.XviD-REWARD\the.mentalist.s01e04.dvdrip.xvid-reward.sfv
Tusse.
