Where do you find the host name for connecting to xbmc via ftp?
does it also matter what port you use? I'm trying port 22.
dreameer111 Wrote:Where do you find the host name for connecting to xbmc via ftp?
Hi.
Port 22 is for SSH, port 21 is default for FTP.
Open a console and type ifconfig, that should give you the ip to use.
/G
Thanks gekados. My mistake. I'm now able to connect but everything in the directory is locked?
I don't have permission to transfer files or create new directories? is there a way to get around this?
if you ask for help i suggest you READ what help you get. twice. and then again. instead of making a screenshot and an arse out of yourself ;P
Missed that spiff
. new problem now.
spiff, be gentle on us Winblows users
