Hi, I just recently got Alaska and was wondering: how do I play physical discs? They don't autoplay for me and there is no option to play disc as there is in other skins. Am I missing something entirely? I feel pretty dumb asking this.
Videos > Scroll down to 'Play Disc' (only visible when a disc is present) or enabled 'Play DVDs automatically' in the settings.
Any possibility you'll implement it as an option on the home menu?
After a bit of testing, it seems that the lost ability to play discs is not the fault of Alaska or any other skin, but of the current xbmc rev. 24195. It could be just me though.
In that light, what rev do you think is the most stable?
Jeseuss Wrote:Any possibility you'll implement it as an option on the home menu?
It is on the home menu, when you go to videos with a disc in the tray it will allow you you press down (without entering videos itself) and you can choose 'Play Disc'
I hope that helps clarify, I am not sure if this request was taken care of when you found out the build you are using is not playing nice with DVDs.
