Full Version: XBMCLive 9.11 - Can't see my Removable Hard Drive
Hi everyone,
I've just installed 9.11 RC1 on my Acer Revo 3600. Everything seems to be working great by can't see my 1TB USB removable hard drive any more.
I can't see it in the file manager, only Add Sources is visible. In 9.04 it came up straight away. Am i missing something?
there is an answer in the first sticky thread above, about 9.11 rc1.
it will point you to here http://forum.xbmc.org/showthread.php?tid=64512.
which tells you to add
<handlemounting>true</handlemounting>
into your advancedsettings.xml file.
which worked for meBig Grin
I did a search but didn't find anything, my bad :o
Thank you for pointing it out to me, I'll give it a try when I get home.
