Full Version: Problem with a HAMA MCE remote
Eventually my problem with this remote can be solved here.
My remote is this HAMA MCE Remote
So i tried this tuturial here: http://forum.xbmc.org/showpost.php?p=450346&postcount=1
but I'm using Ubuntu 9.10 Karmic.
So my Problem is described here:
http://forum.xbmc.org/showpost.php?p=463319&postcount=9
and here:
http://forum.xbmc.org/showpost.php?p=463...stcount=10
so can anybody help me, or can I use the IR-Receiver from HAMA with my Logitech 525 remote ?
Try to set it up with this post, but don't use the phys-device, but the traditional device in REMOTE_DEVICE.
http://forum.xbmc.org/showthread.php?tid=63484
On my machine:
REMOTE_DEVICE="/dev/input/event3"
and
TRANSMITTER_DEVICE="/dev/input/event4"
Good luck.
