Full Version: Sorting
I'm sorry if this is a dumb question, but I'm a total beginner with XBMC.
Surely there must be some way of displaying the list of episodes for any given series of a show in episode number sequence rather than alphabetically?
I been through all the configuration screens and even tried cleaning the library (although it has only just been created) to no effect.
Just go to the OSD sort order chooser and change it Smile
xexe Wrote:Just go to the OSD sort order chooser and change it Smile
I haven't found that! How do I get at it?
Depends on the skin.
On confluence push left on the screen and you will see a new menu scroll out
First off... what skin are you using?
In any of the supported skins, look for the unambiguously called "Sort by" on the upper right side.
http://wiki.xbmc.org/?title=General_Navigation#Sort_by
I'm using the 'Transparency' skin, and I can't see a sort option anywhere
I've found it! What a Pr**t
Thanks guys
I'm also using Transparency and sort on date. But how can I get the newest date at the top or the other way aroound. In Confluence I can get the option for it but in Transparency I didn't found it yet.
Any suggestions?
Wilco
(2015-11-06, 20:33)wbree Wrote: [ -> ]I'm also using Transparency and sort on date. But how can I get the newest date at the top or the other way aroound. In Confluence I can get the option for it but in Transparency I didn't found it yet.
Any suggestions?
Wilco
press the little arrows on the sort button.
