..... there are basically 2 compiled versions floating around out there that i saw... an updated version 1 and an older version 1.1....
kind of makes it hard to know which one is more current.
maybe your software has a way in the gui to list the version number of the software and the installed versions of codecs?
didn't see that.
you seem mighty confused on more than one subject.
surely there's much more than 2 builds floating around.
it doesnt matter though, we don't discuss where to obtain these builds.
for information on how to tell how old a build is, check which file inside the rared archive is the newest, there, et voila, a date!
:kickass:
:kickass:
bonzza great i hadn't changed in while
i am not sure this is right place to mention this..
but here i go...
any one here realize weather icons are hard to see anymore?
is this only me? after upgrade weather icons are too hard to see.. it is like too much transparency level applied or something..
at first i thought weather icons were gone but i see carefully it is there.. just too much transparency.
please let me know whether it is only me or everybody..
thank you for great work!!!! xbmc !!
there is a support forum you know. you need to post there.
also, if you just upgraded to 1.1 point release, that is old. i suggest trying to find a new version.
but please post in the correct forum.
ts
i am sorry... --__--;;
i will use support froums thank you.
btw i use xbmc-2005-03-04..
yahooo !!!!!!!!!!!!!how do you update?
(squirtle @ july 07 2005,22:30 Wrote:yahooo !!!!!!!!!!!!!how do you update?
this announcement was made on oct. 17 2004. do you reckon there has been an update since then or two dude?
to answer your question, you use the search function at the top of the page. search for the term "usual places".
