Hello Guys,
I wanted to install XBMCLive on my ASROCK ION330 (on 4GB USB Stick).
I choose install on complete HDD and selected USB stick.
Partitioning works, but on step installing system (or software) I get an error.
Screen turns into red.
Has somone a solution ? Or is it an error ?
same issue here installing on HDD on ASROCK ION330, stopped in step installing system
here is also the same issue, RC1 installs fine
Have same problem after it has made auto partitions it failed installation with a red screen.
I have same problem on generic PC (Asus MB).
Here are interesting logs from syslog
Quote:Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (libnewt0.52): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (libuuid1): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (ext2-modules): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (partconf-mkfstab): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (squashfs-modules): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (apt-setup-udeb): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: DEBUG: resolver (efi-modules): package doesn't exist (ignored)
Dec 24 12:54:05 main-menu[472]: INFO: Falling back to the package description for console-setup-udeb
Dec 24 12:54:05 main-menu[472]: INFO: Menu item 'live-installer' selected
Dec 24 12:54:11 base-installer: info: Using squashfs support for /cdrom/live/filesystem.squashfs
Dec 24 12:54:11 base-installer: error: /cdrom/live/filesystem.squashfs has failed to be mounted as squashfs.
Dec 24 12:54:11 main-menu[472]: (process:13006): FATAL: Module squashfs not found.
Dec 24 12:54:11 main-menu[472]: (process:13006): FATAL: Module loop not found.
Dec 24 12:54:11 main-menu[472]: (process:13006): mount: mounting /dev/loop0 on /mnt failed: No such device
Dec 24 12:54:11 main-menu[472]: WARNING **: Configuring 'live-installer' failed with error code 1
Dec 24 12:54:11 main-menu[472]: WARNING **: Menu item 'live-installer' failed.
Dec 24 12:54:26 main-menu[472]: INFO: Modifying debconf priority limit from 'critical' to 'high'
Dec 24 12:54:26 debconf: Setting debconf/priority to high
I guess this is a bug?
Hi, trying to install on Asrock ION 330 and have the same issue. Installation fails after partitioning with a red screens and an error saying that it failed to install system. All previous version installed ok.
Is there any sort of log that I can post if it helps (linux noob).
Same here, there is a fault at large which i'm sure will be resolved with a workaround soon
Issue acknowledged, a repack is on its way.
