Full Version: XBMC 9.11 hangs when playing audio, fine with XBMC 9.11 RC1
Hi there
merry x-mas to the xbmc community
Unfortunately I downloaded yesterday 9.11 FINAL but it looks like the audio is
broken with the new release. The problem doesnt occur if I switch back to RC1. I'm running XBMC on a Mac Mini(PPC) 1,25 1Gb RAM
When I try to play a m3U or Mp3 the system would freeze after a few seconds. I tried it with Digital as well as with Analog Audio (no difference).
Here is the XBMC Log
http://pastebin.com/m32a016ea
Could someone have a look at the code changes between RC1 and FINAL ?
As I said it works perfect with RC1
If it helps I can also post the XBMC log for RC1 where the problem doesn't occur.
Thx and greetings from chilly Germany
Still
PPC final should have been built debug (release has no audio) - perhaps it wasn't. Will ping our builders.
Cheers,
Jonathan
Indeed, this slipped in. My apologies. Repack coming later tonight, asap.
TheUni
Ok, repack uploaded. Sorry again for that, should be good to go now.
TheUni
theuni, thank you very much for even looking into it. I'll download and check it.
There is nothing to be sorry about. You guys are doing such a great job, I would love to return it to you somehow.
Still
Ok works no perfect.
Thx again
