2009-12-26, 18:26
Hi all,
first, my setup:
Asrock ION 330 (320GB internal SATA HDD)
XBMCLive HDD Install updated to 9.11 on a USB Thumb drive
2x Seagate Portable 500GB 2.5" USB HDD
Automount enabled
Problem:
My movies are on the internal HDD and on one Seagate external HDD. Running out of free space last week I bought another Seagate Portable HDD 500GB (same version like the other one). XBMC automount both external HDD drives, I can set content on the new HDD etc. But when I want to play a movie that is located on my first external HDD it says that the file is not available and if I want to erase the entry from the database. Playback from the second HDD works fine. When I detach the second HDD and restart XBMC, everything works fine again.
I tested it under Windows with XBMC (new XBMC install, adding movies from both HDDs attached at the same time etc) and everything worked also fine.
So does someone know what the error is and how to fix it?
Thanks in advance
Chris
first, my setup:
Automount enabled
Problem:
Thanks in advance
Chris
