Full Version: Error 11, help
I have been getting frequent crashes with error code 11. Also, browsing either in my video sources folder, or in the TV Shows/Movies library has been very, very slow.
I have up-sampling turned off. The videos which crashed are AVI files with MPEG-3 encoding. I have found that often if reupload I the files to my NAS they play.
I am running Apple TV 2.4 and XBMC 9.04
Thank you for any help.
Here are links to the logs:
CrashReporter.log : http://pastebin.com/m6ab37db8
Console.log : http://pastebin.com/d449d7a4e
Datadog Wrote:I have been getting frequent crashes with error code 11. Also, browsing either in my video sources folder, or in the TV Shows/Movies library has been very, very slow.
xbmc.log would be nice to see, libsmbclient.dylib is crashing. Never seen this before.
Thank you for the quick response.
I have two files one with old, and one without. Both have close timestamps. I had to reinstall about a month ago when I tried to upgrade to 9.11 beta and it crashed. Perhaps the .old file is a remnant? I thought I did a clean rebuild, only copying over my old thetvdb scrapper settings, and thumbnails folder.
here are the two files.
xbmc.old.log http://pastebin.com/d1771915
xbmc.log http://pastebin.com/d743aa679
