Full Version: Adding docus to the library??
Hello to anyone,
I would like to add docus (like Discovery HD Roadtrip USA, etc.) to the library of XBMC. But where to do that?
Because thats not really a movie, its more a series of short films. (Like a season of tv-shows).
Should I add them to the TV-Show library?
Because I think that the TV screaper wouldn't find anythink about this docus.
I know this is a stup.... question, but I would really like to have the docus also in the library of xbmc.
Thanks a lot!
best regards
Andy
You should add it as Tv-Show.
If it's not present on the site you could add it.
http://thetvdb.com/?string=Discovery+&se...ion=Search
Be areful not to waste your time with this. TVDB has strict rules as to what should and shouldnt be added.
Likely your examples are OK but I would read the rules first as if your breach them they will simply delete your work.
Do not assume that since something similar is there already it is implicitly allowed, that is not the case.
Good luck Smile
