Hi Ronie,
Google reader plug-in works fine with other skins, but with transparency it always throws an error.
Error details:
UrlOpen Error (8, 'EOF occured in violation of protocol)
If you have time please check.
it's working fine on my end, so if you can provide a debug log, i will have a look.
been able to reproduce it on windows (no issues on linux so far):
debug log
i have no idea why this is happening with Transparency! only,
as far as i know plugins should run pretty much independent of the skin.
looks like i'm hitting a brick wall with this...
- it only happens on windows, no issues on linux and osx (thanx Amet)
- seems to only affect Transparency!, can't reproduce it with Confluence or PM3.HD
- i can trigger the issue a dozen times in a row, then suddenly the plugins works and i can't reproduce the error again.
- if i delete the plugin and reinstall, the issue starts all over again.
- using a network sniffer i can see xbmc fails to send a SSLv2 Client Hello within 10 seconds, so Google disconnects the session.
similar reports:
http://forum.xbmc.org/showthread.php?tid=46418
http://forum.xbmc.org/showpost.php?p=321...stcount=15
cheers mate, damn stupid of me not searching trac before wasting two afternoons chasing this bug.
if he had posted in the plugins thread where it belongs you wouldn't have wasted time either
true, but when someone mentions it only happens in T! it always gives me the creeps. :-)
sorry Ronie, I should have open this issue in Plugin section , but as I said this plugin works in confluence but not in Transparency, so i thought it is something related to skin.
no worries, i don't mind doing a bit of debugging every now and then. ;-)
I'm hitting this issue using the default XBMC skin and Windows 7.
Any ideas?
Faire Wrote:I'm hitting this issue using the default XBMC skin and Windows 7.
Any ideas?
you can follow the status of this bug / contribute relevant info here:
http://trac.xbmc.org/ticket/5865
that's all you can do i'm afraid.
