Up until now I have been using a xbox dvd remote and dongle on my ubuntu XBMC system. i just got a Harmony One, and want to use it instead. I was easily able to replicate the xbox remote, but I want to do more. I found this guide:
http://forum.xbmc.org/showthread.php?tid=39173 which looks easy enough, but I can't get the extra buttons to work.
Even if I run IRW, the extra button presses just don't register. I think maybe I need to put some more entries into my lircd.conf, but I can't figure out what to add. Can anyone help?
This is what I am trying to add to my keymap.xml:
<universalremote>
<obc5>XBMC.Reset</obc5>
<obc58>XBMC.ShutDown</obc58>
<obc90>XBMC.ReplaceWindow(MyVideoLibrary,movietitles,return)</obc90>
<obc118>XBMC.ReplaceWindow(MyVideoLibrary,tvshowtitles,return)</obc118>
<obc83>XBMC.ReplaceWindow(music)</obc83>
<obc117>XBMC.ReplaceWindow(pictures)</obc117>
<obc176>XBMC.ReplaceWindow(filemanager)</obc176>
<obc71>XBMC.ReplaceWindow(ShutdownMenu)</obc71>
<obc80>XBMC.Takescreenshot</obc80>
<obc144>XBMC.updatelibrary(video)</obc144>
<obc64>XBMC.EjectTray()</obc64>
</universalremote>
Can anyone help? I'm struggling to wrap my head around lirc and how it is configured.
Not sure how much help this will be but check out the following two threads:
http://forum.xbmc.org/showthread.php?tid=47922
http://forum.xbmc.org/showthread.php?tid=45972
You are going in the right direction by switching to the 'universalremote' rather than the 'standardremote' but you also need to make sure that you aren't constraining yourself by using the original mceusb lirc profile since that limits the buttons you have available. The first thread above talks about switching from the MCE remote to a PVR based one and using a different lirc profile etc.
Note I haven't actually gotten round to testing this yet, it's next on my list of projects
As it is I got my Harmony working originally using mceusb and mapped some of the extra buttons such as 'red', 'green', 'blue' to specific actions like you had listed in your sample. It's good but not enough buttons!
Can you configure the Harmony to send keystrokes? Then you can build the SVN version of XBMC that has enhanced keystroke support.
JR
What you need is the "mode2" command and not "irw." This is so you can see what "0x" codes that your remote is outputting. Then they can be added to the lircd.conf file for you to assign different functions from the lircmap.xml. the lircdmap.xml would need to be updated for additional functions from the Keymap.xml file.
Tip: The XBOX DVD Dongle uses the RCA code library. So, you can tinker around with different devices in the Harmony library that will get you more functions to get the "0x" codes from. Altogether I got about 50-60 distinct "0x" codes
This thread may be of help:
http://forum.xbmc.org/showthread.php?tid...ight=mode2
Marbieskarb Wrote:What you need is the "mode2" command and not "irw." This is so you can see what "0x" codes that your remote is outputting. Then they can be added to the lircd.conf file for you to assign different functions from the lircmap.xml. the lircdmap.xml would need to be updated for additional functions from the Keymap.xml file.
Marbieskarb, would you mind posting your Lircmap.xml, and lird.conf files?
I'm using a Harmony 880 remote. I've got the basic xbox remote buttons mapped, and a few extra ones. I'm trying to get additional functions mapped, like XBMC.ShutDown(), but I can't figure out how to get obc# codes that are necessary (I've scoured the forums, which have been helpful).
In the xbmc logs file, I'm only getting the obc codes for the default xbox remote buttons, and a few extra ones. They're not displayed for the extra buttons I've added. I get response from all the buttons via irw, and raw mode2.
Here's my Lircmap.xml file in progress:
<remote device="XboxDVDDongle">
<play>PLAY</play>
<pause>PAUSE</pause>
<stop>STOP</stop>
<record>REC</record>
<forward>FORWARD</forward>
<reverse>REVERSE</reverse>
<left>LEFT</left>
<right>RIGHT</right>
<up>UP</up>
<down>DOWN</down>
<select>SELECT</select>
<back>BACK</back>
<menu>MENU</menu>
<title>TITLE</title>
<info>INFO</info>
<skipplus>SKIP+</skipplus>
<skipminus>SKIP-</skipminus>
<display>DISPLAY</display>
<pageplus>PGUP</pageplus>
<pageminus>PGDN</pageminus>
<myvideo>MYVIDEOS</myvideo>
<one>1</one>
<two>2</two>
<three>3</three>
<four>4</four>
<five>5</five>
<six>6</six>
<seven>7</seven>
<eight>8</eight>
<nine>9</nine>
<zero>0</zero>
</remote>
My lircd.conf file
# LIRCD configuration file for Xbox DVD Kit
# Marko Friedemann <mfr|bmx-chemnitz.de>
# brand: Microsoft
# model: Xbox DVD Remote
# supported devices: Xbox DVD Remote via xpad-ir driver
# comment: EXPERIMENTAL
begin remote
name XboxDVDDongle
bits 8
begin codes
SELECT 0x0b
UP 0xa6
DOWN 0xa7
RIGHT 0xa8
LEFT 0xa9
INFO 0xc3
9 0xc6
8 0xc7
7 0xc8
6 0xc9
5 0xca
4 0xcb
3 0xcc
2 0xcd
1 0xce
0 0xcf
DISPLAY 0xd5
BACK 0xd8
SKIP- 0xdd
SKIP+ 0xdf
STOP 0xe0
REVERSE 0xe2
FORWARD 0xe3
TITLE 0xf7
PAUSE 0xe6
PLAY 0xea
PGUP 0xb8
PGDN 0xc5
RESTART 0xa5
SHUTDOWN 0xac
TV 0x8a
MOVIES 0xe5
MYVIDEOS 0xc4
SETTINGS 0xbf
UPDATELIB 0x6f
SDMENU 0x7f
REC 0xe8
end codes
end remote
Log file
23:00:32 T:3078674320 M:1440387072 DEBUG: LIRC: Update - NEW at 99173:000000000000007f 00 SDMENU XboxDVDDongle (SDMENU)
23:00:33 T:3078674320 M:1440395264 DEBUG: LIRC: Update - NEW at 99967:000000000000007f 00 SDMENU XboxDVDDongle (SDMENU)
23:00:34 T:3078674320 M:1440395264 DEBUG: LIRC: Update - NEW at 101009:000000000000007f 00 SDMENU XboxDVDDongle (SDMENU)
23:00:36 T:3078674320 M:1440395264 DEBUG: LIRC: Update - NEW at 103055:000000000000006f 00 UPDATELIB XboxDVDDongle (UPDATELIB)
23:00:37 T:3078674320 M:1440399360 DEBUG: LIRC: Update - NEW at 104432:00000000000000c4 00 MYVIDEOS XboxDVDDongle (MYVIDEOS)
23:00:37 T:3078674320 M:1440399360 DEBUG: OnKey: 7 pressed, action is 122
Ghostdog,
how did you get those hex codes to put in your lircd.conf file for your custom buttons? IRW doesn't recognize my custom buttons when I press them.
