I am running Camelot and Ubuntu 9.10.
I'm using my iPod touch to Control XBMC (
Collect 3).
When I press the Shutdown Icon in XBMC, I would like it to shutdown Ubuntu as well. The ipod touch cannot control Ubuntu so i have to hunt for my other remote to turn off the PC. I'd like it all done from the touch. I figure I would have to edit a script file somewhere.
Can someone lead me in the right direction?
Start xbmc with "xbmc-standalone" instead of "xbmc". Normally that should suffice (at least with a standard ubuntu installation).
I installed xbmc from the gnome desktop synaptic package manager.
I have a shortcut on the gnome desktop with the command "xbmc".
Can I simply change the command to "xbmc-standalone"? or Do I need to remove the xbmc install from synaptic and then re-install the xbmc-standalone version?
Can the xbmc-standalone be started when I'm in gnome? Lets say I'm browsing firefox and then want to watch a movie. Will I have to logout and then login as user "xbmc"? Or can I make a gnome desktop shortcut with the command "xbmc-standalone"?
In the default, confluence skin. System > System (Please tell jezz_x I sound like an idiot typing that so maybe he'll fix it
) > power saving > shutdown function. Set it to shutdown instead of quit.
althekiller Wrote:In the default, confluence skin. System > System (Please tell jezz_x I sound like an idiot typing that so maybe he'll fix it ) > power saving > shutdown function. Set it to shutdown instead of quit.
That worked. Thanks smarty pants! Thanks aswell Clumsy for your help, al's way was just quicker and easier!
Sorry for jacking the thread, but maybe someone here can help me. I have lost the reboot and shutdown options from the
System > System > power saving > shutdown function menu. Anyone got any hints or tips?
