Full Version: Refresh rate switching using a remote!
Hi All
I have recently started looking at XBMC on OSX in place of Plex which I have been running for a while. Mainly for 3 reasons:
* XBMC seems to be able to play DVDs in the HTPC drive
* XBMC does media flagging out of the box
* XBMC seems a LOT closer to doing refresh rate switching automatically.
Re this last point - I was able to set PLEX up to do refresh rate switching using my harmony remote. The steps were as follows:
1.) Download cscreen.zip from post #6 in this thread http://forums.macosxhints.com/showthread.php?t=59575
2.) Extract and put the csreen file in the usr/bin directory
3.) Created 2 applescripts that called cscreen with the parameters I required (24 and 50Hz refresh rates @ 1920x1080 32bit colour)
4.) Put these scripts in the Plex scripts folder
5.) Created the following Harmony.xml file and and put it in the Plex keymap folder.
<keymap>
  <global>
    <harmonyremote>
      <F11>Plex.RunScript(Run24Hz.applescript)</F11>
      <F13>Plex.RunScript(Run50Hz.applescript)</F13>
    </harmonyremote>
  </global>
</keymap>
Now, in Plex, when I use the button that corresponds to F11 and F13 on my harmony remote I can switch the refresh frequency from the comfort of the sofa!
What I want to do is replicate this in XBMC Cool
So far I have:
1.) Copied the scripts to the XBMC Scripts folder in the user/Library/Application Support/XBMC/Scripts folder.
(I can access these through "Scripts" in the XBMC GUI and run them successfully)
2.) Copied the Harmony XML file to user/Library/Application Support/XBMC/userdata/keymaps/ and changed Plex to XBMC in the xml file.
This is where I am stuck. I don't think I have the syntax correct for calling the scripts from the harmony.xml file in XBMC, in fact I am not even sure it should be called Harmony.xml! Can anyone point me in the right direction? Looking at the files in the system/keymap folder in XBMC it looks like Harmony support has been implemented in a different way than in PLEX. Can anyone confirm?
Thanks!!! Cool
anyone ever find the source code for cscreen ? I'm pretty sure I know what it's doing but would still like a peek inside without having to disassemble it.
I found this - its not complete but gives an idea of what its doing (not that I would know! Not a programmer or even close to being one Big Grin)
* main.c
* newscreen
* Created by Jeffrey Osterman on 10/30/07.
* Copyright 2007 Jeffrey Osterman. All rights reserved.
* PROVIDED AS IS AND WITH NO WARRANTIES WHATSOEVER
#include <ApplicationServices/ApplicationServices.h>
void MyDisplaySwitchToMode (CGDirectDisplayID display, CFDictionaryRef
mode);
int main (int argc, const char * argv[])
    int h;                                  //horizontal resolution
    int v;                                  //vertical resolution
    CFDictionaryRef switchMode;        //mode to swich to
    CGDirectDisplayID mainDisplay;     //ID of main display
    if (argc != 5)
         printf("Expected 4 inputs, but only received %i\n", argc-1);
         return 0;
    if (!strcmp(argv[1],"-h"))
         h=strtol(argv[2], NULL, 0);
    else if (!strcmp(argv[1],"-v"))
         v=strtol(argv[2], NULL, 0);
    else {
         printf("Error! Expected first argument to be -h or -v\n");
         return 0;
    if (!strcmp(argv[3],"-h"))
         h=strtol(argv[4], NULL, 0);
    else if (!strcmp(argv[3],"-v"))
         v=strtol(argv[4], NULL, 0);
    else {
         printf("Error! Expected third argument to be -h or -v");
         return 0;
    mainDisplay = CGMainDisplayID();
    switchMode = CGDisplayBestModeForParameters(mainDisplay, 32, h, v,
NULL);
    MyDisplaySwitchToMode (mainDisplay, switchMode);
    return 0;
mode)
    CGDisplayConfigRef config;
// 1
    CGBeginDisplayConfiguration (&config);
// 2
    CGConfigureDisplayMode (config, display, mode);
// 3
    CGCompleteDisplayConfiguration (config, kCGConfigureForSession );
// 5
also found thid:
* setgetscreenres.m
* juanfc 2009-04-13
* Based on newscreen
*    http://forums.macosxhints.com/showthread.php?t=59575
* COMPILE:
*    c++ setgetscreenres.m -framework ApplicationServices -o setgetscreenres
* USE:
*    setgetscreenres 1440 900
bool MyDisplaySwitchToMode (CGDirectDisplayID display, CFDictionaryRef mode);
    int    h;                             // horizontal resolution
    int v;                             // vertical resolution
    CFDictionaryRef switchMode;     // mode to switch to
    CGDirectDisplayID mainDisplay;  // ID of main display
    CFDictionaryRef CGDisplayCurrentMode(CGDirectDisplayID display);
    if (argc == 1) {
        CGRect screenFrame = CGDisplayBounds(kCGDirectMainDisplay);
        CGSize screenSize  = screenFrame.size;
        printf("%d %d\n", screenSize.width, screenSize.height);
        return 0;
    if (argc != 3 || !(h = atoi(argv[1])) || !(v = atoi(argv[2])) ) {
        fprintf(stderr, "ERROR: Use %s horres vertres\n", argv[0]);
        return -1;
    switchMode = CGDisplayBestModeForParameters(mainDisplay, 32, h, v, NULL);
    if (! MyDisplaySwitchToMode(mainDisplay, switchMode)) {
        fprintf(stderr, "Error changing resolution to %d %d\n", h, v);
        return 1;
    return 0;
    if (CGBeginDisplayConfiguration(&config) == kCGErrorSuccess) {
        CGConfigureDisplayMode(config, display, mode);
        CGCompleteDisplayConfiguration(config, kCGConfigureForSession );
        return true;
    return false;
Can you point me to where I could find the XBMC config file for the harmony remote?
Thanks for the code refs, I'll check into it.
Harmony support is in keymaps/joystick.Harmony.xml.
Thanks - I will have a play later when all the relatives have gone home Laugh
I can't wait to see the auto refresh rate switching working on OSX, I have too many files now to remember what rates they are all at. I have been looking at using an NFO file to store the framerate so that it can be displayed by the skin so I at least know which rate to set it to manually.
If there is anything more I can do to help (testing etc) just drop me a PM - would be really happy to help!
