Full Version: "movies" and "tv shows" disappeared from home menu?
hiSmile
just done a fresh install of camelot onto a ubuntu desktop yesterday.
i installed showmix 2.5 and added the font pack, set it up as i wanted it and added sources for my tv shows and videos.
everything was normal until i added a couple of home movies i had to the movies source, when i returned to the home screen "tv shows" and "movies" was missing??
they're selected as showing in the settings, and i even tried disabling them, rebooting the re-enabling them and rebooting, but its still the same.
i've also purged the settings and removed all sources.
any ideas guys??
Should really be posting in the showmix forum but I think it might be because you haven't populated your Library press c on the folder in videos and go to set content.
do you mean the showmix forum on here mate? as i couldn't find a specific forum for it?
i selected the sources and set the content, the only thing i hadn't done was scanned them all in, this was when i wen't back to the home menu and noticed that tv and movies had gone.
so basically if i setup the sources, the tv and movie buttons on the home screen will disapear, until the souces are scanned to populate the two, tv and movies.
too late to try now anyway, i'm doing a full ubuntu up install againUndecided
thanks for your timeSmile
