Full Version: Disabling video navigation slideout
I actually don't know what the menu is called. It slides out when you move left on a vertical library list, or up on a horizontal library list and it gives you options to change the library view, sorting, etc.
When unexperienced users are navigating they often fall into this menu and get stuck and/or start messing things up. I'd like to move that menu to something other than the regular navigation buttons. Is there a way to do it without modifying the skin?
Simple option no, Pretty much much every skin has "hidden" options that are activated the opposite way you are navigating...
After an hour or so with XBMC you get the hang of it and relaize why waste space with menu options...
To see a skin with the options plainly visible try PM3D
