Full Version: Apple Remove DVD menu
Hello Folks,
I recently upgraded to 9.11, with launcher 3.2.1. Fist, let me say thank you. XBMC is an amazing piece of work.
I am using the Apple Remote, and with version 9.04, when playing a DVD, the play/pause button of the remote was able to select items in the DVD menu. Now, with 9.11, the play/pause button always shows up the playback menu, so there is no way to actually exit the DVD menu to start the movie.
I tried messing around with the
/Applications/XBMC.app/Contents/Resources/XBMC/system/keymaps/joystick.AppleRemote.xml file, but it doesn't seem to change anything.
Any idea ?
I removed the local settings (/Users/frontrow/Library/Application Support/XBMC/userdata/Keymap.xml) and now everything works. Probably a leftover from 9.04.
