I doubt that this will work. So no occurrence of this library in system32 or WINSXS?
You could do me a favor and look for environment vars and if anything is in the registry which we can use.
WiSo Wrote:I doubt that this will work. So no occurrence of this library in system32 or WINSXS?
No.
Quote:You could do me a favor and look for environment vars and if anything is in the registry which we can use.
Found this and I think it should work:
[HKEY_LOCAL_MACHINE\SOFTWARE\Broadcom\MediaPC\CrystalHD]
"InstallPath"="C:\\Archivos de programa\\Broadcom\\Broadcom CrystalHD Decoder\\"
so the dll can be found at:
"C:\\Archivos de programa\\Broadcom\\Broadcom CrystalHD Decoder\\bcmDIL.dll"
xexe Wrote:That makes sense. Currently I have to run GL anyway as the DX version wont suspend and resume and i cant get it to produce a log to file a report on it.
Could you please try a rev >=26284 and see if it makes any differences?
WiSo Wrote:so the dll can be found at:
Yes. I use a spanish XP version so that is the "Program Files" folder.
@davilla: I found out that videos encoded with the L5.1 profile doesn't sttuter at the start or when seeking -->
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 3h 17mn
Bit rate : 2 723 Kbps
Nominal bit rate : 2 783 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.118
Stream size : 3.76 GiB (86%)
Writing library : x264 core 60 877tw
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=6 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2783 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
but videos encoded with L4.0 or L4.1 drop frames during a period of between 5 and 20 seconds -->
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 1mn 3s
Bit rate : 5 979 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.159
Stream size : 45.4 MiB (88%)
you have to load the bcmDIL.dll from the Braodcom installation path.
I own a Broadcom BCM70012 and tried to run the dx version on Win7 and Vista, it craches on Opening the bcmDIL.dll from special path. Did not tried the GL version yet. But it works on DX, ok a bad black/white output.
Since i really was not able to find the bug, i wrote a little test application, which will detect the installation path, open the driver gets the status and version then it closes it.
On the attachment you'll find the test application and a screenshot.
Use the Setup from Broadcom Crystal Setup to install the new device driver fo your BCM70012/15. Then start the Test Application.
In XBMC, we need to add a registry detection.
#define REG_PATH "Software\\Broadcom\\MediaPC" // HKLM
#define REG_PRODUCT "CrystalHD" // "70010" for older setups
#define BRC_DLL "bcmDIL.dll"
RegGetValue -> REG_PATH\\REG_PRODUCT\\"InstallPath"+\\BRC_DLL
Cheers, GeminiServer
Hi! Anyone able to tell me whether CrystalHD correctly decodes VC-1 interlaced material? Such as the m2ts files found on Life (BBC documentary series) and Torchwood BluRays.
@Geminiserver: davilla told that broadcomp needs load the firmware and ofc we would like to make it easy for the user.
Unfortunately the broadcomp driver won't install if it doesn't find a card. I've ordered one but this will take some time. Feel free to rewrite it to use the path stored in the registry
A600 Wrote:Tested and working fine here
I can also confirm that it works in a Revo 1600 with the Broadcom card in the empty mini PCIe slot. H.264 in mkv container works very well, both 720p and 1080p. This is under Windows 7, GL build 26307.
anyone can put a compiled version of this trunk on megaupload or rapidshare ?
Thank you,
xexe Wrote:Then there are ALL the windows users that don't want to use an external player. All this for < $20... bargain.
I thought it was $70 bucks, where can i get it for under $20?
ebay is the simple answer shipped from HK
