Full Version: All Web Scripts Failling
Hi Folks,
Ive been searching and searching but so far have come to no answers. Basically every time I run a script that requires data from the net i.e. Apple Movie Trailers / CNN / Revision3 etc I get an error saying "Script Failed!"
Im running the latest version of XBMC on Windows 7 with the default skin. Ive also attached a log file. If anyone has any thoughts it would be much appreciated as this is beginning to really drive me nuts now.
Thanks very much in advanced.
Cheers.
https://dl.dropbox.com/u/1161781/xbmc.log
20:06:32 T:5128 M:2552512512 DEBUG: FreeLibrary(MSVCR71.dll) -> 0283BB28
20:06:32 T:5128 M:2552512512 DEBUG: FreeLibrary(MSVCP71.dll) -> 0283BA88
remove those two files from lib/python
clintjb Wrote:Hi Folks,
Cheers.
ESPN Video is video plugin, it needs to go to /plugins/video and not scripts folder.
I suggest you use SVN repo installer to install plugins, it will place it in a correct place.
Also please use pastebin.com for debug log, makes it easier to read.
Zeljko
