I have a Sony BD remote and if I want to play a folder with DVD files I have to root around for the correct dvd file. Is there a way to just select play on the folder instead, like the old days with the old Xbox?
Rather than copying the dvd files, create an ISO image of the DVD and upload that. it will play just like the DVD and you dont have to select the correct VOB file...
Thanx for the info but that doesn't answer my question. I am not about to spend another two months convert 1000 movies into ISO files.
Turn stacking on, and those folders will be replaced by file items.
I turned on stacking and nothing happened. It went into the directory showing the contents as before.
then you most likely do not have proper dvd folders.
