Full Version: has anyone managed to fix the resume problem on ion asrock 330
Hi
I have a quick quesiton. Since a week I try to fix the "resume after suspend problem" on my Asrock 330.
I have Camelot on my maschine an everything works good but not the resume after suspend.
The point is I followed the guide http://wiki.xbmc.org/?title=Enable_Wake-On-Device and it works after I changed S4 to S3 but only until reboot. After reboot the system looses the settings.
I also installed the Script http://wiki.xbmc.org/?title=Automatic_li...ume_script but it does not works after reboot.
Is there any chance to fix that? Its quite anoying...
regards
Did you definitely do the Committing to rc.local part?
Just checking as I had the same issue you describe, until I realised this part needed to be done to make it permanent.
