Hello,
i own a ION 330 HT and replaced the sata drive by a 8GB SSD from transcend.
I am able to install the so called "xbmcfreak" image (RC1) but not the image directly from XBMC itselve.
The installer does not detect my drive but it installs perfectly onto a 4 GB usb key.
Any idea? Already tried the IDE and AHCI mode... makes no difference.
Happy new year!
Martijn
Whatever that image is, it's not ours and not supported here.
I don't want support on his image, i need some help/info on the xbmc-live image.
As stated above, i'm running on usb stick now with xbmc-image. But prefer to run on ssd drive.
Using asrock ion 330 ht.
All i get is the installer offering me to install on i-scsi.
Like
this message.
Thx
I figured that i'm able to install with the BETA1 image but that's the last image that detected my transcend 8 GB device.
I am having the exact same problem as godfather007. I get the screen here:
I am trying to install it to a PC with a Intel motherboard and a SATA hard drive plugged into SATA port 0. Very basic.
The install worked great with 9.04.1 Live CD. Anyone got a solution?
Just to add:
i'm trying to run xbmc from a TS8GSSD25S-S
Which, like screenshot above, does not get detected.
In the beta 1 it does get detected. (skip the mentioned xbmcfreak image, i checked with the xbmc.org-images).
It's like the driver does not trigger the devices well.
Could do a seperate ubuntu install on it...
just downloaded beta1 to freshly install.
The setup says: "detected sata-raid devices; shall i enable them?"
Answer:
YES ends up with no SSD
NO ends up with SSD.
Going to try to pkg update.
Any hints to look for while updating drivers etc?
