Full Version: Importing a unknown show to database?
Hallo!
I have here a tv shwo for Kids
filename
Barbapapa/Season1/S1E1 - Die Geburt.avi
i think the seasons are not online in databases so when i import itit only shows
1x01
1x02
1x03
how can i get the additional info for example "Die Geburt" from the filname to the list?
thanks
tom
Use a .nfo file for the show.
Alternatively, add the show to thetvdb.com
if it was't in the online database, you would get nothing. The show just has very little information there.
But othervise, what jmarshall said. Use nfo files to flesh out the info or populate thetvdb.com with good info in your language.
Adding the info to tvdb is the far simpler option and helps the community as a whole as well. Do that Smile
